I took the day off from work and went out all day for a nearly perfect day. Before heading out though, I did a little research here on the forum about heaving to -- I've never done it before, and it seems like something very worthwhile to know how to do.
I got everything in position and prepared to head into the wind when I noticed the load-bearing jib sheet was going to put all its load across the lifeline once hoven to. The sheets go under the lifelines, so once the jib backwinds and comes across the deck (I was using about 95% today as winds were a bit strong) the sheet is coming from the car outside the lifeline, over it, and to the jib.
I decided not to try the heave to today, and check with you all. I'm sure this is either a simple thing or I'm doing something wrong, but I didn't want to put that kind of stress on the lifeline without asking for some help first.
Any problems with crossing the lifeline? Or am I just missing something in my setup?
Under the lifelines? If I get the picture, I think you're rigged wrong. The sheet should be over (outside of) the lifelines to the jib car block on the track, and <i>then</i> led under the lifeline back to the winch. The C-25 is not designed for sheeting inside the lifelines, even though that means the jib/genoa will lie over the forward end of the lifeline. That's just how it is.
Mike, Dave has it correct... the sheet should not be going under the life line. If done that way, the working sheet might seem less fouled but the lazy sheet will foul big time and cause problems tacking the jib and as you had foreseen, fouled when trying to heave to.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Arlyn Stewart</i> <br />Mike, Dave has it correct... <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">...or partly right--I just realized I had the wrong boat. Sorry.
Wow! This makes sense and I hadn't even thought about it from the perspective of the normal rigging. I just spent an hour looking at photos of other 250s to try and discern how they'd rigged them, and sure enough many were rigged without going under the lifelines. Makes a lot of sense for the heave to, but is taking my brain a bit to understand from a normal beam/broad reach jib position... however, Arlyn's point about the lazy sheet pretty much hammers it home.
Shoot - all this time I was sorta wondering why the lazy sheet always took a bit of a shake during a normal tack. Shoulda thought of this earlier!
Now I'm excited to go re-rig and sail foul-free! Thank you both - and Dave - no worries on the boat - 100% understood what you were saying in either case.
