Recently, I was at a boat show. There was a booth showing an Oceanair hatch screen. It looks like it would work well on the forward hatch thought it is pricy. I was wondering whether anyone has installed this item.
We haven't gotten that fancy. We just used velcro & flexible screen. Put velcro around the hatch inside then sew the other half of the velcro to the screen (cut to size). It's easy to store (folds up) & it works.
I tried that but instead of sewing the velcro to the screen I just stuck the velcro to the screen. The velcro kept peeling off the screen. Did you use velcro all around the screen or just in spots?
The wife made a screen for the forward hatch. She took measurments of the hatch fully opened and laid out the screen to those angles and sewed it up. I supplied some SS bullet fishing weights and she made up a sleeve long enough to go all around the bottom of the screen and just big enough to put the weights in. The screen goes over the hatch and the weights hold it there.
I put velcro around the hatch and stitched velcro to some no-see-um netting. It worked great initially, but now a few months later (and with little use) the velcro tape is peeling off from around the hatch.
Cathy (or anyone else), have you had any problem with the velcro peeling from around the hatch? I relied on the adhesive backed velcro tape. Any kind of glue that will hold this stuff better?
My wife is questioning what kind of stitching should be used on the velcro. Did you stitch it with a machine or by hand? Did you sew it once in the middle or down each side?
I was thinking of using epoxy to hold the velcro to the liner. Perhaps, that would work on the screen too.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Steve Raffel</i> <br />I tried that but instead of sewing the velcro to the screen I just stuck the velcro to the screen. The velcro kept peeling off the screen. Did you use velcro all around the screen or just in spots? <hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
I did that first - it lasted for about a year then I got sick of sticking the velcro back on. I simply hand sewed the corners & a spot in the middle of each side. If you had a heavy duty needle for your sewing machine that would work too.
I stitched the fuzzy velcro tape to the screen - running a stitch down each side of the tape. I put some thin flat nylon webbing on the opposite side with the screen sandwiched in between. I'm sure it was overkill, but I was using no-see-um netting which isn't very sturdy, so I felt the need to reinforce it.
I went the same route as Tompotter, I find in the middle of the night I can pop my head up to check my anchor location without disturbing the screen. It was a lot more work to sew, but I can also adjust the hatch and take a peek outside with no effort. I sewed in stainless chain to weigh down the edges.
i made a screen for the companionway door this summer, but i could not figure out how to make the screen for the front hatch. thank you for the idea to add weights or chains in the pocket around the edges. that sounds like a perfect solution, because i too have found that velcro, or anything else you try to stick does not stay very long because of all the humidity. for those of you who asked how to sew the screening, i had no problem sewing it with my regular sewing machine, with a regular needle. i found the screening material at my local fabric store, very inexpensive and easy to work with.
I bought no-see-um netting by the yard through the REI website. Stitching it on a sewing machine was pretty easy.
My new plan is to follow the others and make a weighted net to toss over the hatch. The velcro holds fine - I just wish the adhesive did. Until Suzie mentioned it, I hadn't thought abut the convenience of being able to pop my head through the hatch without disturbing the screen.
I found the no-see-um screen at our local HD and used the stick on velcro. Have not had a problem with it coming off yet, but the one thing it does is block out about 50% of the air that my wind chute is pushing down the hatch. Presently working on finding a 5K BTU heat pump and 1K watt generator to replace it all.
On my forward hatch screen I just used the stickum velcro, but the main hatch screen sits in the channels and rolls up for storage.
Rolled up for storage
Installed in the hatch
It is made with 5/16 dowels and 3/8 plastic tubing. The tubing supplies the pressure to hold it firmly against all surfaces. It is not my idea, I found it in one of my old sailing mags., but it works great and is cheap.
I made a screen to fit my companionway. I used the starboard door as my sizing model and used wood to create the frame with screen stapled to it. During the heat of the day, or during light rain I can use the screen but keep the hatch closed with the sunbrella cover in place but folded under.
your screens look great. ours is the same, but we made ours to fit with the pop top up. we velcro the top to the bar that holds up the pop top and have a dowel at the bottom. it folds up the same way, but we have the advantage of the head room of the pop top. someday we are going to get a digital camera..and post the pictures..
Yep, I have the 25 x 25 and I like it a lot. We have fits of meat bees. It keeps them out so it gets a thumps up here. It also has that peek-out-ability and stows neatly. I'm not very handy so I bow to already made stuff.
Terry, thanks for your suggestion. I bought one this weekend and it seems like the easiest solution. Our boat is out of the water until May but I tested it in the boatyard. Like you I am not handy so this is a good solution.
