My boat is suffering from the "keel clunk" syndrome. I do not have a clear picture in my mind of what the mechanics look like with regards to the keel support. Are there images that I can be directed to? I notice that a Keel Hanger CAsting Kit is available? Is this usually necessary and does it help with the Keel clunking? How does the Keel Centering Spacer Kit differ from "Shims" ? Can the shims be replaced while the boat is still on the trailer? I am a long way from any boat yard, and would like to do anything I could myself. Is this wise or possible?
The clunk is only heard when sailing, usually after a tack when the boat starts heeling a bit.
I purchased a Kit from Catalina, that had the disks and epoxy, everthing you need. Installation of the spacers was only part of the solution however. My Keel clunk had a lot to do with play between the iron keel and the bronze Keel pin. Excess slop contributed to a lot of the clunking. I had the keel dropped and sent to a machine shop that fitted a bronze bushing in the keel.
A tip that may be quite obvious for most, but it caught my attention just the same:
When using the "all-thread" technique to lower the keel for the hanger and pin replacement, be very careful !
While I was slowly running the 3/8" nuts down the all-thread, I noticed that a couple of the all-thread rod lengths were turning with the nut. I didn't catch it at first. I went back and checked that all were all the way up and seated. From this point on, I attached a pair of vice-grips to the lower end of the rod.
Obvious I know, but worth mentioning due to the risk of a 1500 pound hunk of metal falling!
Oh, yes, I did have wood support right below the keel, so it wouldn't have gone too far. But, we don't want this much weight traveling anywhere unexpectedly :)
Hope I help someone. This group has helped me a lot over the years.
Just reread all the info listed and there wasn't any mention of using carpet. I started using carpet years ago and have checked the bolts and pin yearly especially the last two years being made aware of the maintenance by the forum. Got the carpet idea from the 22's in Mainsheet. I use heavy carpet attached with construction adhisive and it seems to spread the load over the more area than the pads. The carpet doesn't show when the keel is all the way down. Anyone else using carpet?
How thick was the carpet? Shag? Berber? Indoor/Outdoor? One piece on each side of the keel? What brand and model of construction adhesive?
You have me curious now.
By the way, by looking at impressions left on the keel by the hangers, I was able to draw a line from just below the pivot hole to the front radius of the keel, representing the line of demarcation between the part of the keel in and out of the well.
I needed this, so as to be able to place the shims/carpet in the correct place.
If do not remove your hangers or can't see this impression I spoke of, I made a measurement that may help:
89.5" from the bottom and trailing edge of the keel, to the upper leading edge radius. Draw a line from this tangent back towards the pivot point, to a point about 5/8" just below.
