I contacted Chris at onlineoutboards today regarding concerns expressed here about warantees. He assured me/us that, "NO PREDELIVERY INSPECTION form is required and that this is an attempt for dealers to scare people into using their extremely expensive services and overpaying for engines! IT IS NOT REQUIRED !!!!!!!!!!!The warranty is 100 % VALID without the pre-delivery inspection"
All's well that ends well. Here's Chris' reply to my "beef": And BTW, engine remounted, starts and purrs like a dream.
"Hi John,
I have had a chance to speak with my service manager at our dealership and this is what we can do.
I understand your frustration with your engine not being able to start using the electric start out of the box. I also understand this was a simple fix by the dealer as the engine was slightly engaged in gear when you attempted to start it, thus engaging the neutral safety switch, and would not allow the engine to fire up. The neutral safety switch is a standard safety feature on all outboards. It also would have been corrected using the trouble shooting guide in the owner's manual, or my initial response item #1 in our previous email correspondence.
Your "dealer" however, in my opinion, has ripped you off and has misled you. We would NEVER charge anyone $85.00 for a pre-delivery inspection, one that isn't even required by the manufacturer for warranty purposes as they mislead you to believe. Your dealer has flat out lied to you and you can contact the manufacturer directly to confirm this. ALL Tohatsu/Nissan outboards are FACTORY TANK TESTED before being crated! Tohatsu/Nissan's warranty labor rate (on covered items) is more along the lines of $30.00 for this type of issue, not $85.00. The fix to your issue took less than 60 seconds. The pre-delivery inspection should not take more than 20 minutes tops. Keep in mind, that the problem you had was not a warranty covered item as it is considered by the manufacturer as a simple trouble shooting issue, kind of like not hooking up the gas line or the safety stop lanyard properly. Another words, it would be a standard check item as the manual states (making sure the engine was in the neutral position). The problem is that people try to shift the engine without the engine running, thus no back pressure on the propeller and the bullet in the lower unit that engages forward-reverse gears. The shift mechanism is mechanical and relies on backpressure from the exhaust to slowly turn the propeller allowing the bullet to do its job. If you notice, when the engine is in neutral the propeller is turning just slightly. This provides the movement needed to allow the bullet to engage the gear. When the shifter is moved while the engine is not running, it causes it to jam and engage the neutral safety switch. It is something to be careful about and check in the future should you have trouble starting the engine in the future.
I understand you wish us to pay $85.00 to reimburse you for expenses with your "dealer". We are willing to refund you $42.50 (1/2 your bill) for your troubles with the following reasons:
1. This problem could have been resolved via our initial email (item #1) or by phone, and it is an issue that would be classified as something that could occur with any outboard on occasion (standard check item). I understand that you may be new to this issue and not familiar with it.
2. We never heard from you following our first email to you (we asked you to contact US if the 3 listed trouble-shooting items didn't solve your issue, of which item #1 would have). We would have been happy to help locate a reputable dealer to perform this work for you at a reasonable rate if it proved necessary, which in this case it doesn't seem it should have been necessary at all. In addition, most reputable dealers would have performed this service at no charge, the neutral safety issue fix, as it takes virtually no time to solve and educate the customer about. We have done this with many customers who have purchased elsewhere - its part of being a Tohatsu/Nissan dealer. Had there been communication between you and our dealership we would have never authorized $85.00 for this type of issue and would have gotten Tohatsu/Nissan involved if necessary to see a more reasonable rate out of this dealer or found another dealer who I'm confident would have done it at either a much lesser rate or no charge at all.
If you'd like, we'd be happy to credit your card by $42.50. Please let me know if you would like us to do so. We apologize you had this inconvenience with your new outboard. We wish you would have contacted us before electing to take it to this dealer and having this bad experience. Please let me know if there is anything else I can help with either now or in the future.
1.) Tohatsu/Nissan's recommended service center for your area is:
Company Min-Mar Marine Center Address 1519 W. Anaheim St. Long Beach CA 90813 Phone 562-590-5055 Fax 562-590-9271
2.)Duplicate bill of sale on the way per your request!
3.) Confirmed again with Allan in service @ Tohatsu/Nissan(and informed him about your situation) that NO PREDELIVERY INSPECTION is required for warranty purposes and you should never "dry-shift" the engine when its not running because of the neutral saftey issue we've been discussing.
Hope all is smooth sailing from this point forward! Enjoy your new outboard!!!
P.S. If you're sharing this with the board, you may want to post this message so others in your area can see the recommended service center also. We love helping all our sailboaters out there in need of engines with the best prices around on one of the best engines for the job. We have many satisfied sailboaters using engines obtained from www.onlineoutboards.com and we value each of them and their referrals. The dealer mentioned in the email above doesn't sell engines either; they are an authorized service dealer only and specialize in servicing. Many "service-only" dealers exist around the country and are sometimes a better alternative to the stuck-up dealers that try to make a killing on the engine sale and the service following the sale. A lot of these dealers try to scare customers with the service aspect, but the truth is that the maker, Tohatsu/Nissan, is the ultimate entity standing behind the product and reimbursing the dealer for the expense of warranty service. I have sold Tohatsu/Nissan engines for 15 years and out of all the brands I've handled over the years they are the absolute best when it comes to standing behind their product. Please wish everyone on the board a Happy New Year from www.onlineoutboards.com! Happy sailing!!!
