 UV Protection ON 110
Steve Raffel
Initially Posted - 10/09/2001 :  17:01:11  Show Profile
Is the standard 110 jib that comes with the 250 UV protected on both sides of the jib? I wonder if the sail has one side only UV protection. I looked at the panels and while the luff panels appear to be a different color, there doesn't seem to be a diff
bill bosworth
Response Posted - 10/09/2001 :  21:21:47  Show Profile
Steve;
I can't answer your question about what side the uv protection is on, but I have done a couple of things. When I first got my boat I found that the previous owner had a dacron pannel installed on the sail for protection. The problem was that i
MarkTM
Response Posted - 10/10/2001 :  09:13:42  Show Profile  Visit MarkTM's Homepage
I had a sock made by Catalina Direct for the same reason: improved sail shape, especially in light winds. Cost me just a hair over $200 (including shipping) and is well made. The jib halyard (which is not used for its intended purpose) is employed to ra
Steve Raffel
Response Posted - 10/10/2001 :  22:33:38  Show Profile
I found the sock had too much windage. When it blows in the marina the foil really moved.
Steve Raffel
C 250 WK # 408
MarkTM
Response Posted - 10/11/2001 :  09:51:04  Show Profile  Visit MarkTM's Homepage
When I raise the sock, I send an extra line with it. I wrap this line around the sock (tightly) to reduce windage. This does a good job of keeping the sock from flapping in the breeze.
Mark Melchior
C250 "Lorelei" #384
[url="http://www.texassailor.
Steve Raffel
Response Posted - 10/11/2001 :  22:15:00  Show Profile
Mark, thanks that's a good suggestion. I'll try it next year when I am back in the water.
Steve Raffel
C 250 WK #408
