 Dinghy engine stowing question:
AADIVER
Initially Posted - 02/20/2006 :  14:26:47  Show Profile  Visit AADIVER's Homepage
I would like to mount my 2 horse Honda air cooled dinghy engine on PRETTY PENNY. Since we don't have any T connections on our aft railings, any ideas/suggestions on how to do it? Foto's, por favor
Frank Farmer
Long Beach, CA
aa.diver@verizon.net
http://mysite.verizon.net/aa.diver
PRETTY PENNY
'01 C-250 WK, Hull #558
Bubba
Response Posted - 02/20/2006 :  18:13:40  Show Profile
You mean something like this, Frank?
http://mywebpages.comcast.net/frayed-knot/projects/images/IMG_1034.JPG
Dinghy motor mount made from a 6" x 3/4" PCV plank purchased at Lowes. The three layers are held together with seven 1/4" x 2" carriage bolts and barrel nuts.
Response Posted - 02/20/2006 :  18:25:49  Show Profile  Visit britinusa's Homepage
Nice Job Dave! Hmm I can see my Bridge supports being connected to something like that.
BTW, you officially have he longest url in any of the member info links!
Tom Potter
Response Posted - 02/20/2006 :  18:55:42  Show Profile
I made one using some scrap teak. I cut out a board 6"x7", 1-1/2" thick and used 2 stainless steel U bolts just big enough to fit around the aft rail and into the wood but not all the way through the wood, I counter sunk the area for the nuts and washers so they would not stick out past the thickness of the wood. 1 of the U bolts fits on the horizontal part of the rail and the other on the vertical part of the rail. Sorry I don't have any other pictures but this one.
Edited by - Tom Potter on 02/20/2006 19:04:47
AADIVER
Response Posted - 02/20/2006 :  20:02:49  Show Profile  Visit AADIVER's Homepage
Thanks, y'all. I think I'll go with TOMPOTTER's. The engine mounted on the catbird seat would get in the way of the cats
Oldnewtimer
Response Posted - 02/21/2006 :  06:16:06  Show Profile
Here's a thought (which probably has been thunk before) and as it's sort of related to this I thought I'd toss it in: what about a detachable/emergency bracket thingie that could maybe just slip over the swim ladder (in the down position). Something over the second step, the one below the feet that hold the ladder away from the stern, would probably give the right height. A board thick enough for outboard to attach to could sit on the step with something to hold the edges to the side rails of the swim ladder, probably with some capacity to tighten it down so the thing can't ride up the swim ladder side rails. Then if your larger auxiliary goes bust you might be able to use your dinghy outboard for emergency power. Seems like the swim ladder would be sturdy enough for the outboard to push against, and somebody with some fabrication skills might be able to conjure up a very simple bracket with either no or few moving parts. Obviously the ladder would add drag, but I'd think a 2-3 hp outboard would be able to move a 250 at several knots at least. Again, just for emergencies, but if small and simple enough you might be able to justify the weight/stowage expense on the basis of safety?
Perhaps if you could figure out a way to integrate this emergency swim ladder function into your ourboard motor mount, so that with perhaps just a little extra work or hardware you could make it so you can move the mount down to the swim ladder in an emergency, then there would be virtually no extra cost in terms of weight/stowage.
Just a thought, remember I don't even own a boat yet
AADIVER
Response Posted - 02/21/2006 :  22:19:29  Show Profile  Visit AADIVER's Homepage
I simply placed the outboard's transom bracket over the top (actually the bottom when down)swim step and secured the engine with a bike chain and lock. Pics tomorrow. Of course I can't use the ladder when the engine's mounted on it, but on upcoming seasonal warm weather trips, the engine will be on my towed dinghy.
AADIVER
Response Posted - 02/22/2006 :  18:49:10  Show Profile  Visit AADIVER's Homepage
Here's the picture of how I stow my 2 horse on my boat. My Humminbird Piranha MAX 10 fishfinder transponder is attached to the long PVC pipe extending up in back of the catbird seat. I lower it to get depth readings, raise it when not in use. I keep the screen unit in the port cubbyhole.
zeil
Response Posted - 02/23/2006 :  22:12:18  Show Profile
Frank
Is your 2hp aircooled Honda outboard a long shaft model and is it equipped with a clutch allowing you to idle the motor without the propellor turning? The loccal Honda dealer suggests that the clutch is only available with standard shaft. Are you happy with the 2 hp outboard.. and have you used to propel your 250?
AADIVER
Response Posted - 02/23/2006 :  23:35:45  Show Profile  Visit AADIVER's Homepage
No, it's only for my Watertender 9'4" dinghy. It's a standard length shaft. Decided it won't woik on the ladder so I'm just going to keep it on the dinghy with its cover. The dinghy's in the water in my slip, port side. I'll have my "boat monkey" clean its butt along with the big 'un. I like the engine very much but because it's air cooled it's LOOOOOUUUUUUD!!
