 Need a measurement
Initially Posted - 04/04/2006 :  21:17:17  Show Profile  Visit Champipple's Homepage
I know some of you guys have every inch of your boat measured. Can any of you tell me what the rough dimensions of the setee locker area, starboard side is. It is the middle of the three where Frank Butler put the watertank. Or the forwardmost of the the aft if you count it as two. I am referring to the area from the wooden insert forward
If you didn't have an original water tank then you might not have this area...
D. Wolff
DPO C25 Hull 401
Currently Sailing "Champagne and Ripple" 1982 O'day 30
Chief Measurer 2002-2006
Vice-commodore 2007
Response Posted - 04/05/2006 :  12:20:06  Show Profile  Visit Frank Hopper's Homepage
42
thanks for the fish
Edited by - Frank Hopper on 04/05/2006 12:22:05
Response Posted - 04/05/2006 :  13:23:49  Show Profile  Visit Champipple's Homepage
PS - I've come to find out hat the later models have different settee configs too.
42 Frank? thanks for the fish - Yah lost me somewhere?
Response Posted - 04/05/2006 :  14:14:29  Show Profile  Visit Frank Hopper's Homepage
Hitchiker's Guide to the Universe, the answer to the ultimate question, the meaning of life, and everything... 42
Thanks for the fish
Response Posted - 04/05/2006 :  14:44:15  Show Profile  Visit Champipple's Homepage
Now I get it
stampeder
Response Posted - 04/05/2006 :  19:20:44  Show Profile
I forget what the question was.
Response Posted - 04/05/2006 :  21:33:59  Show Profile  Visit Champipple's Homepage
Here's the question -- What size tank will fit
stampeder
Response Posted - 04/05/2006 :  22:24:42  Show Profile
Frank must have gone to bed, or else he'd probably have jumped all over this one...42, is the answer to Life, the universe and everything, but it took so long to find the answer, that they forgot what the question was.
So, to actually answer your question, I think you should go with the blue one.
Don't hesitate to ask if you have any more technical questions.
Response Posted - 04/06/2006 :  09:02:29  Show Profile
On my first boat, the bag style tanks were the first things I threw out, but it looks like the technology has changed somewhat since then.
Response Posted - 04/06/2006 :  12:05:28  Show Profile  Visit Champipple's Homepage
They appear to be pretty darn good technology. I can get a plastic tank cheaper, but it limits my location options
Response Posted - 04/06/2006 :  12:28:17  Show Profile
I find these bags to be quite adequate!
Anybody know if this would fit under the settee?
Response Posted - 04/06/2006 :  15:18:10  Show Profile  Visit Champipple's Homepage
Don -
We are tossed around the idea of buying two bags and putting some sort of snap on off fittings on them. One will be full of Gin the other Water. Wouldn't that be a hoot - dry martini's out of the faucet!!! We also contemplated a y valve thing, or a hot gin cold water idea, but the weight and possible extra pump make it prohibitive.
farrison
Response Posted - 04/06/2006 :  18:50:20  Show Profile
Duane;
Since it appears that you can't get a straight answer from all of these jokers, if you still need the measurment, I can get it from my 82 WK, which has the fresh water tank (white poly) under the stbd settee, and shares the settee space with twin 12 volt batts in a seperate compartment. There is a plywood partition in the water tank section that holds the tank away from the hose connections, input, outlet and vent(the vent is just a tube that runs up between the hull and the hull liner). This partition is only about 4-6 inches from the battery compartment wall. The bulk of the space is taken up by the tank, and 36"-46" sounds about right. Does this sound like your set-up too? Let me know if you want measurements off my boat.
Response Posted - 04/06/2006 :  21:22:16  Show Profile  Visit Champipple's Homepage
It sure does Paul, you can't fault them completely though, I participated in the jokery. I'll be down at my boat tomorrow so I will have time to measure myself. But Thank You, I appreciate your offer.I'll be installing this tomorrow:
farrison
Response Posted - 04/10/2006 :  14:06:00  Show Profile
Duane;
Nice panel. It appears that the switch labels will be lighted, correct? Where did you mount it? (It's Monday afternoon, and I assume it slipped right in over the weekend and is all hooked up).
I rewired mine last year, replaced the original 5 switch factory panel with two 6 switch panels from West Marine because they would fit in the original location behind the galley sink. I also remounted the double battery main switch and the Shore A/C power breaker on each side of the dual panels.
I would love to see a picture of your installation when you're done with it.
Response Posted - 04/10/2006 :  18:55:54  Show Profile  Visit Champipple's Homepage
I'll have to get a pic of the finished product. I'll be posting the trials and tribulations separately later tonight. I will not ever be posting a picture of the spaghetti going into the back of the panel. That is still embarassing. - look for a different post
dw
