 Interlux Interprotect 2000E epoxy water barrier
Initially Posted - 05/28/2002 :  03:55:13  Show Profile
I'm sanding below the waterline for the first time in 5 years in preparation for applying new VC 17m (also 5 years old.) MAN, IS THIS EPOXY EVER HARD STUFF! I started out with 80 grit and had to settle for 36 grit (using an oscillating sander.)
Once I started sanding I realized just how deep the dimpling was from applying the epoxy with a roller. Of course, always looking to eek out another nanoknot, I'm sanding the 2000 until it's completely smooth. Talk about drudgery <img src=icon_smile_dead.gif border=0 align=middle> !
Steve Madsen
#2428
OJ (Ode to Joy)
Douglas
Response Posted - 05/28/2002 :  17:23:39  Show Profile  Visit Douglas's Homepage
My thoughts and best wishes are with you. I did and entire bottom job this past winter. Good thing I had several months to get the job done. I had to rig a cart to lay on and slide around under the boat. My arms felt alot better working from my back than bending or standing. I also replaced the to hulls. I put a two part epoxy on and a new bottom coat. There are lots of pictures under the title bottom rework but I cant remember if I posted under general or C-25
Doug&Ruth
Wind Lass
Tacoma Wa.
Response Posted - 05/31/2002 :  12:11:26  Show Profile
Douglas, I appreciated your suggestion about employing a cart while sanding the bottom of the hull. If I don't apply enough pressure to the sander, it won't cut the 2000E effectively. Placing a mechanic's creeper on top of a couple pieces of scrap 6X6s gives me perfect leverage.
Thanks dude!
Now I'm wondering how America's Cup boat builders measure surface tension to achieve optimal laminar flow <img src=icon_smile_wink.gif border=0 align=middle> !
Thru-hulls go in this weekend - photos to follow!
Steve Madsen
#2428
OJ(Ode to Joy)
[url="http://catalina25-250.org/photo0.htm/"]<img src="http://www.catalina25-250.org/photo/ode075.jpg" border=0>[/url]
Edited by - OJ on 05/31/2002 12:18:51
Response Posted - 05/31/2002 :  21:22:45  Show Profile
Whew! I hope you guys on your mechanic's carts are well shielded--plastic coveralls, hoods, masks, goggles,... My bottom job will be next Fall/Spring starting with a peel-away stripper and finishing with sanding as necessary. It helps that my fin keel boat will be high on poppits--I'll be able to do most of the job standing up. <img src=icon_smile_approve.gif border=0 align=middle>
tinob
Response Posted - 06/01/2002 :  09:15:33  Show Profile
Hi all,
I hurt just reading of your travail. When I removed my bottom I opted for a blasted finish followed by the interlux barrier coats and Micron csc. It recently became necessary to remove the last coat of Micron--problem with it bonding. While mindful of Daves or Dougs admonition to take care when sanding this paint I used a wall board sander with a hose tied to the top to wet sand. It helped to control the dust and added to the efficiency of the grits cutting.
Val on "CALISTA" #3936
Val Bisagni
Buzz Maring
Response Posted - 06/01/2002 :  10:27:14  Show Profile
Hi Steve,
I just did the bottom on my boat, too ... what a job ... it took twice as long as I expected, and it hurt about four times as much as I expected. My boat and trailer are on a slight incline that is covered with rocks ... the mechanic's creeper wasn't an option. I got cut and bruised at least once by every sharp thing protruding from that #&&**!! trailer, and I felt like I had been in two-a-day football practice at the end of every day.
Anyway, another idea to cut down on the dust ... if you have a sander with a built-in dust vacuum, remove the dust hopper or bag and duct tape a shop vac to your sander. I did that on my orbital sander ... it wasn't that much harder to maneuver, and it sure cut down on all that toxic dust flying around.
'Hope you "sail" through the project ... good luck!
Response Posted - 06/02/2002 :  20:37:39  Show Profile  Visit Leon Sisson's Homepage
Doug & Steve's suggestion of the mechanic's creeper reminded me of what I used. I needed to work on the broad flat bottom surface while the boat was on a trailer parked on concrete. I put two plastic recycle bins (like large milk crates) on top of a mechanic's creeper, and then a maybe 2'x5' piece of scrap plywood over those, topped off with a layer or two of old carpet. Turning the rectangular crates various ways and shimming the plywood with 4x4 scraps allowed me to adjust the overall height of the rolling work stand. It was a lot more comfortable than either bending over and reaching under the boat, or squirming around on my back on concrete trying to stretch my arms high enough to touch the hull.
MarkTM
Response Posted - 06/02/2002 :  23:09:50  Show Profile  Visit MarkTM's Homepage
Steve,
Does this mean that your boat was previously painted with VC-17? If so, you shouldn't have to do any sanding. VC-17 redissolves when one or more new coats are applied. You merely need to power wash the bottom prior applying the new coats. That's the joy of VC-17! Maybe I misunderstood what you were saying.
Mark Melchior
C250wb "Lorelei" #384
[url="http://www.texassailor.com/"]<img src="http://www.texassailor.com/texas.gif " border=0>[/url]
<font size=1>(click flag to visit Central Texas Sailor)</font id=size1>
Response Posted - 06/03/2002 :  09:21:17  Show Profile
Funny you should mention the recycling bin Leon - I placed the mechanics creeper on top of one over the weekend while sanding the tail section of the hull - got a lot funny looks from the neighbors though, but that's nothing new.
Mark, I agree and that was the original goal. Problem is I applied the 2000E so heavy (to achieve the 10 mils) that I ended up with pretty coarse stipling. So coarse that lake slim would <i>permanently</i> attach itself to the lower portions of the stipling. This coarseness also defeated, to some the degree, the purpose of applying something as smooth as VC17m. So, I'm sanding the bottom to smooth out the surface to achieve another nanoknot or two and keep lake slim from attaching to the stipling. Next time, the goal will will be to do as you described. Actually, I lost more VC17m from power washing than anything else!
MarkTM
Response Posted - 06/03/2002 :  10:23:48  Show Profile  Visit MarkTM's Homepage
Although my marina's yard powerwashes, I just use a normal hose with a hose-end sprayer. Gets the slime off without removing any noticeable amount of paint. I try to pull the boat out on its trailer at least once a year to remove the slime and touch up the paint where needed . . . usually another coat around the waterline and minor touch-ups elsewhere. I give the paint 30 minutes and then splash the boat. My bottom still looks new after four years using this technique.
Mark Melchior
Response Posted - 06/03/2002 :  11:11:40  Show Profile
Exactly
Douglas
Response Posted - 06/03/2002 :  12:12:52  Show Profile  Visit Douglas's Homepage
On the subject of dust collection. I used a 5 hp shop vac with canister type internal filter. As well as the canister filter I also installed the internal hepa filter bag so that I had two filters. I did tape my vac to the dust collection nozel of the sander. I used a makita 8 hole orbital. I used 80 grit paper and was very carefull not to stay on one area long enough to get into the glass. When I pulled the hepa filter to change it (Twice) It was heavy and full of bottom paint. I did wear personal protection gear and a resperator.
Doug&Ruth
Wind Lass
Tacoma Wa.
Response Posted - 10/31/2002 :  12:24:54  Show Profile
<font color=blue>Mark, you're right. After smoothing out the Interlux 2000 water barrier this spring - I reapplied the VC17m. I rinsed the bottom on Tuesday with only the pressure provided by a garden hose and sprayer head. Very clean and no paint running across the parking lot <img src=icon_smile_approve.gif border=0 align=middle> !</font id=blue>
jellyfish
Response Posted - 10/31/2002 :  14:02:23  Show Profile
my hat off to you guys! there is no way I would tackle that job. the boat yards around here charge $450 for a new bottom job including the haul out. that usually last 3 years so for $150 a year they can have it!
Response Posted - 10/31/2002 :  15:40:08  Show Profile
<font color=blue>Dan, you've heard the phrase "no rest for the wicked"? Well, I never rest . . .</font id=blue>
Steve Madsen
#2428
OJ (<img src=icon_smile_evil.gif border=0 align=middle>de to Joy)
