Has anyone used the Forespar Twist Lock Tiller Extension??? What did you think??? Sounds like a great way to lock the tiller when needed and also get the ability to lean out and 'peek' around the sails while still holding the tiller. Thanks
John; I use a forespar twist lock tiller extension, I also installed the extension lock boxes on both the port and starboard sides (I got them at west marine). I've been using the extension for years and would hate to be without it. The lock boxes allow me to lock the ball shaped end of the tiller extension in place, adjust the heading of the boat, then twist lock the extension, to hold course. I find that at times the twist lock doesn't want to lock without some fooling around. I'm not quite sure how to correct the problem. I hope some of that made sence. Bill, C250wb #134 Serendipity
I have used the Forespar twist-lock extension for a few years too. I'm pretty sure mine is the shorter of the two. Even with the short one, I can steer from the stern pulpt seat while on a run.
I only have one lock box though. I was able to place the cut-out for the lock box right behind the cut-out for the combing box. If the lock-box leaks, it will just run into the combing box and out the drain - no leaks in the cabin.
Did you mount the extension on the top or the bottom of the tiller??? How far back from the front of the tiller??? Thanks again, I really appreciate the info.
How does the Forespar twist lock tiller extension unit when set in the lock box compare to the Tiller Tamer? More or less effective in holding the boat on course for short periods of time?
Frank, I'd say they're both equally effective at holding the tiller in place. I personally prefer the tiller extension because... well, it's a tiller extension.
I have both but I don't have the lock box for the Forespar...yet. With the Tamer I can make small, subtle adjustments, but the Forespar is either locked or unlocked, no fine tuning.
Frank, to fine tune the Forespar twist-lock, you hook the knob in the lockbox and twist the extension to unlock it. You can then set the tiller exactly where you want it and then twist to lock the extension in that position. If I'm going to be up and down a lot, I just leave the extension in the lockbox and hooked to the tiller, but with it twisted to the unlock position. That way I can steer the tiller as needed then with a twist of the wrist it's locked and I can get up and leave it for a minute. It's just as handy as a tiller tamer, but due to the min and max length of the extension, you can't put the tiller hard over while hooked up like that.
I finally got around to installing my tiller extension and lock boxes. I found out that the shorter model Forespar, when fully extended, is about two inches too short to put the tiller midship. Just FYI for anyone else thinking about getting one.
Can anyone share their experience in mounting the Forespar Lockbox? I have an old one and wonder if the design has changed. The cutout clearance is very small...it looks like one small mistake and you have a bigger hole than you would need!!! Thanks.
It comes with a template. I cut it out, traced it with pencil on the boat, drilled holes in each corner, and cut it with a jig saw. I was careful to cut less than more and actually had to use rough grit sandpaper to enlarge the hole a little more. Oh and yes, I was nervous the entire time. Something about cutting holes in a perfectly good boat. I've heard that taping over the gel before you cut it keeps it from chipping. I just use a fine tooth blade and lots of patience.
I'd use tape to reduce chipping on fiberglass, go slow, and one more thing - I'd cover the face plate of my jigsaw to reduce the chance of leaving marks from the metal plate. Might not be necessary but in my mind it is nice to reduce the risk so you can concentrate on getting the line right instead of worrying about damaging the surrounding surface.
