 Yamaha 9.9
shemp
Initially Posted - 07/11/2006 :  10:52:08  Show Profile
I am not getting very much water exiting the cooling outlet. I spoke with a Yamaha mechanic and he told me that the port may be plugged and probably not a problem. Does anyone know of a way to check / clear this?
Jeff Dowling
Chicago
203
mfasis
Response Posted - 07/11/2006 :  11:49:20  Show Profile
What year is your motor? Is it new?
I have a 97 Evinrude 9.9 2 stroke that came with my boat. The first season I used it I had a steady stream coming out of it but not with much force. In the off season I replaced the impeller (which was in rough shape) and was very surprised with the difference when I first ran it this season.
You might want to look into that as well.
Mark
Turk
Response Posted - 07/11/2006 :  16:00:42  Show Profile  Visit Turk's Homepage
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by shemp</i>
<br />I am not getting very much water exiting the cooling outlet. I spoke with a Yamaha mechanic and he told me that the port may be plugged and probably not a problem. Does anyone know of a way to check / clear this?
If your port exits the housing using a rubber hose, take the hose off and run a wire through it. My 2.3 merc had the build-up right where the rubber hose was clamped to the pipe on the block. Did the trick for me.
also, take a look at your impeller in the lower unit. If you don't have a manual, google it - you will find it on the internet.
shemp
Response Posted - 07/11/2006 :  21:58:51  Show Profile
Its a 2003 but barely used
atgep
Response Posted - 07/12/2006 :  00:05:57  Show Profile
The 2 outboards I have a owned both acted the same(johnson&tohatsu). The telltale always has more force when it is cold. The tap is upstream of the thermostat in the cooling system. After the engine warms, it is acceptable to see a drop in pressure at idle as the t-stat is open. Above idle, you should have a healthy stream. If there is any doubt, get it checked or replace the water pump. You could quickly wind up with a boat anchor.
Tom.
Capt. Kurt
Response Posted - 07/15/2006 :  12:08:18  Show Profile
I have the same outboard and also had the same problem. The water was trickling out instead of the ussual stream of water. I tried the garden hose connected to the adaptor on the motor but that didnt clear the obstruction. I then held a water hose right up to the outlet of where the water stream exits the motor. It doesnt make a perfect seal but it was enough pressure to clear out whatever was obstructing the flow and has worked fine ever since.
Hope that helps!
Kurt
C250WK 'Tortuga'
