 Spinnaker basics
kayest
Initially Posted - 07/16/2006 :  13:44:05  Show Profile
I've owned my Cat 25 for over a year now (first boat) and I figure its time to try out the spinnaker thats been sitting in the basement. Problem is, I have no idea how to set it up. Here it is:
I assume this is a symmetrical spinnaker? What do I need to fly it? It didn't come with a pole. Do I need one? What are the attachment points on the boat? Can anyone point to a tutorial or pictures? Thanks in advance.
-Steve
Edited by - kayest on 07/16/2006 17:15:21
djn
Response Posted - 07/16/2006 :  14:43:03  Show Profile
Hi Steve, your pic did not come through. All I see is an red X. Cheers.
Response Posted - 07/16/2006 :  15:40:45  Show Profile  Visit Champipple's Homepage
If it is a symetrical spinnaker, take a look at my teck tip...
If it is asymetrical (probably the case if you didn't have a pole) then start by flying it like a big jib. Halyard to the head, sheet to the clew and attach the tack to the bowstem.
Lay it out on the grass.....if both luffs are the same length, you are symetrical
Edited by - Champipple on 07/16/2006 15:42:58
kayest
Response Posted - 07/16/2006 :  17:20:00  Show Profile
Sorry for the bad picture link. I think its OK now.
I didn't pull out a tape measure but it looks pretty symmetrical. I will check the tech tips. This is probably a really stupid question, but can a symmetrical be flown like an asymmetrical?
Response Posted - 07/16/2006 :  17:42:57  Show Profile  Visit Frank Hopper's Homepage
That is a symmetrical radial head with a narrow foot, that makes it's pocket deep and the sail generally unstable. A pole will be required, (with up and down hauls to lock the tack height), and it will only perform on deep broad reaches and runs. These are difficult sails, you must keep the shoulders from collapsing and it should be flown with a good crew. It is kinda like the whomper. My last symmetrical was a tri-radial which had a flatter cut and could reach fairly high.
Response Posted - 07/17/2006 :  20:35:34  Show Profile  Visit Champipple's Homepage
That's a cross cut symetrical sail. I disagree with Frank, that sail is not Unstable. They can be difficult to handle with untrained crew. I highly recommend getting someone on board who knows what is going on for the first few times. OR....start in less than 7 knots of wind and build up.
You should really use a pole and a setup as Frank Notes. Most of the information you will need is located in my tech tip.
I have, in the past flown one of these like a asymetrical, but you can't run down as far that way and if you head up to high, you stand a chance of being way, way overpowered.
To do this, tie a 3 or 4 foot line to the bow stem and attach the sail to it. The run your sheets outside of the forestay. You will need blocks as far aft as possible. (this might be a problem on the newer models where the jib track stops at about the cabin coaming.)
Feel free to email me directly with any questions.
Edited by - Champipple on 07/17/2006 20:38:43
Response Posted - 07/17/2006 :  21:52:35  Show Profile  Visit Frank Hopper's Homepage
Duane is the better source on this.
Response Posted - 07/17/2006 :  23:02:28  Show Profile
Or you could just pole out a 155% and run a broad reach...just as fast as a chute
Derek
MattL
Response Posted - 07/18/2006 :  11:55:37  Show Profile
I have a couple of cleats at the back corners, could a couple of blocks be attatched to these to get a spinny sheet way back threre, or is that too far back?
Response Posted - 07/18/2006 :  12:30:44  Show Profile  Visit Champipple's Homepage
No, actually that is about right. Make sure those cleats are backed with something to distribute the load. They weren't backed from the factory.
