 Shelf Life of 3M 101 bedding compoung
John P
Initially Posted - 07/17/2006 :  09:49:43  Show Profile  Visit John P's Homepage
So, I decided to reinstall all the teak yesterday, only to find that the tube of 3M 101 I bought about 2 weeks ago would not come out of the tube.
I insterted a wire probe and found the 1st inch of the tube to be very very stiff, the center was in good shape though. No matter how much pressure, I applied, I could not get any to come out, although I did see some slight leakage at the plunger end of the tube.
Anyone else have any problems like this?
'84, C-25, SR/FK, #4663, "ILLUSIONS", Chazy, NY (Lake Champlain)
http://www.sailblogs.com/member/illusions
Justin
Response Posted - 07/17/2006 :  09:53:40  Show Profile  Visit Justin's Homepage
I thought I remember reading that putting it in the fridge helps. I bought some Boat Life Caulk back in January and have kept it in my fridge ever since and it is still good.
Buzz Maring
Response Posted - 07/17/2006 :  11:12:04  Show Profile
Hi John,
I've had the same problem many times.
I complained to the folks at West Marine, and they admitted it is a common problem. According to their sales staff, the smallest pinhole, loose cap, or whatever can make a tube of 101, or 4200, etc. begin to set up. Anyway, the good news is, they said just bring the tube back with a receipt, and they'll exchange it for a new one.
I used to keep two or three tubes of sealants, caulks, etc. in my tool bag, but I learned the hard way they usually go bad before I get around to using them. I suppose it's still a good idea to have a tube of some multi-purpose stuff on the boat, but now I buy only what I need, and only when I'm ready to use it.
John P
Response Posted - 07/17/2006 :  11:33:11  Show Profile  Visit John P's Homepage
I have had the same probs with already opened stuff, but this is the first "off-the-shelf" failure. Then coupled with the fact that the tube runs over $20, it makes it that much worse. But, that is the downside to not having a large marine store nearby.
frog0911
Response Posted - 07/17/2006 :  17:31:22  Show Profile
The answer is return it to the store if you have the receipt and then put the new tube in the vegetable drawer of the fridge when done. I have had life seal, life caulk and 5200 in my fridge for over a year. When I need it, I pull it out, place in sun for awhile before use and then back in fridge when done.
