 Loose foot main question
AADIVER
Initially Posted - 07/24/2006 :  13:25:29  Show Profile  Visit AADIVER's Homepage
Does a loose footed main put additional stress on the mainsail track slugs? One of my slugs at the luff end of a batten broke, but only after I loose footed my main. Thanks.
Frank Farmer
Long Beach, CA
aa.diver@verizon.net
http://mysite.verizon.net/aa.diver
PRETTY PENNY
'01 C-250 WK, Hull #558
Russ.Johnson
Commodore
Response Posted - 07/24/2006 :  13:55:51  Show Profile
Frank,
A big stress on the slugs can happen during reefing.
Do you reef very often?
Russ (#793)
AADIVER
Response Posted - 07/24/2006 :  17:44:22  Show Profile  Visit AADIVER's Homepage
Ah,ha! Yes, we did reef last Friday, then noticed the broken slug after we shook it out. Bad product that breaks during a normal sail adjustment.
Russ.Johnson
Commodore
Response Posted - 07/24/2006 :  21:23:51  Show Profile
Frank,
Here's an article on reefing from [url="http://www.sailmaker.com/articles/reefing.htm"]Pineapple Sails[/url]
When reading this article keep in mind one of your "Luff Sliders" broke.
And the C250 has a "Single-Line Reefing System".
I had to read this article 3 times but it makes sense.
Now, I make sure the reef tack is tight before the reef clew is tight.
Russ (#793)
Tom Potter
Response Posted - 07/25/2006 :  14:24:22  Show Profile
Good article Russ, thanks.
Response Posted - 07/26/2006 :  04:57:48  Show Profile
When Catalina discontinues a practice, it is likely because the practice is costing them and owners. From '97 to '01 or so, Catalina routed the jiffy reef line to the cockpit on the WK model but then discontinued doing so.
The reason, likely either popping of sail slugs or worse, damage to the sail from use of the winch for reefing.
Owners of course can route it there, but on their repair nickle for sail repairs.
If the winch must be used.... be sensitive to the strain on the line and if too great... sort out the resistance.
Edited by - Arlyn Stewart on 07/26/2006 05:04:12
