My main has two holes in the head plate to attach the halyard. They both are horizontal to each other and spaced about 3 inches apart (one closer to the luff and the other closer to the leech) I've always hooked to the one closer to the luff.
Whats the purpose of having two, I expect it has something to do with sail shape but what effect does it play?
The headboards are sort of a standard item that are purchased in large quantities from outside vendors. Many of these vendors are supplying headboards to several sail lofts and the sails end up on lots of different boats.
The two holes in the headboard are so that you can position the halyard shackle on the headboard so-as to allow for a vertical (read as relatively low friction) hoist. The halyard should be parallel to the mast all the way up to the top. The pulley system in the mast head cap determines whether to use the forward or aft hole. For most all of the Catalina models, the forward hole is preferred because the halyard pulley sheave is just forward of the aft edge of the mast. And the aft hole has little or no function.
I've found that the hole closest to the luff works well the other hardly at all. I assume the aft hole would serve as a downhaul location. Only Gary knows for sure and he hasn't said Anyone ever ask him?
The hole closest to the mast track is the one you're supposed to use in order to get the fairest halyard lead, unless you have an oversized masthead sheave in which case you'd use the other grommet for a fair lead up the mast.
I don't believe the second hole has anything at all to do with sail shape. Think of it as a spare in the event the primary hole is damaged.
Bill, That makes a lot of sense, that second hole in the head board has always interested me. I've tried using it but didn't notice anything different, however I was looking for sail shape. My thought was it would make the leech tighter or something like that. Now that you explained it, it makes perfect sense. I'll check the vertical run of the halyard next trip to the boat. Thanks.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by tinob</i> <br />I assume the aft hole would serve as a downhaul location...<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote"> I think you'd find that would pull the headboard to the side, causing the upper slug to bind and making it tougher to douse the main.
The aft hole has no function. Oh I could make up a cool story about it was put there to attach a pendant or such but not realy. Just count your blessings. My new boats mast is 62' and once up I cant see much of the top of the sail without me glasses.
The aft hole does have a function when required to reef in high winds. Check this reefing article at the bottom under " Key items to look for" third bullet. http://www.sailmaker.com/articles/reefing.htm
Me too. It's obvious that is what the second hole is for, however I question the load differences on a 2 lateral difference over a 30 foot hoist.
I do agree with their Jiffy Reef assessment to the point of it being a good single hand alternative. I'm considering a reefing hook this coming fall for next season and eliminating the single line reef for both clew and tack.
I understand what he is saying about the single reef system, but I like the fact that I do not have to leave the cockpit when single handing the boat when the wind is blowing enough to need a reef. At that point, I think my mind is on safty not max speed. If I have someone else on board, that would be a different story. Cheers.
I have a question. Does anyone have any pictures of their reefing system. I single handing alot and right now I have to leave the cockpit. I really don't like this because we get strong gust here in the desert. Dennis I would like to see your set up. Thanks again for all the help.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by RedRedWhine</i> <br />I have a question. Does anyone have any pictures of their reefing system. I single handing alot and right now I have to leave the cockpit. I really don't like this because we get strong gust here in the desert. Dennis I would like to see your set up. Thanks again for all the help.
There are two distinct groups of reefers. The single line and the dual line, (with the ram's horn variation). I am a two line guy. In this photo you will see a black line cleated on the starboard side of the mast, it goes up through the reef tack and down to the base of the mast out to a deck organizer and back on the port side to a clutch. You see a blue line running along the boom to a cheek block and down to the mast base, over to a deck organizer and back to a clutch on the starboard side. There are a lot of rigging ideas on the pages of the url in my sig.
a jiffy reefing system is probably the easiest. There are a number of ways to rig it, but this is the absolute most basic...sorry no pics, but I'll try and explain as best I can.
Splice an eye into an end of 5/16 or 1/4 line. Attach the line through the tack pin of the sail via the spliced end. Run the line up to the reefing point then back down the other side to a turning block. (you can get a carbo from harken for less than 10 bucks that will hold a line that size)
From that block run the line along the boom to where the reefing kringle is on the leech of the sail. again another turning block on the boom, up through the kringle and down the other side to a horn cleat. You can run the line through the center of the horn cleat for convenience.
To reef, loosen the halyard to the premarked spot and take in on the reefing line.
The aft turning block needs to be equal to or farther aft than the spot where the kringle lies on the boom while reefing.
If you have two reefs you can repeat this going back the opposite direction.
Hi Don, this week I am finally cleaning up my mess from the last six months and will take pics, and post them, of all the work I've done on this boat...including the reef system. Cheers.
