 12 volt fridges
AADIVER
Initially Posted - 08/22/2006 :  22:04:57  Show Profile  Visit AADIVER's Homepage
Is a 12 volt fridge too much of a battery drain for 2-3 day cruises?
If not, how about this one from Sports Chalet:
Koolatron Auto Kool Wheeler
Item no: 2149398
OUR PRICE: $88.99
List Price: $106.99*
The Koolatron™ Auto Kool Wheeler features built-in wheels and a unique fold-out handle for easy portability. The 33-liter capacity can hold up to 54 12-oz drinks. The cooler can be used in chest or fridge position and includes a dual-position shelf/divider. The full-opening lid includes a small hatch for quick, easy access. There's no need for ice to keep things cool, just insert the 12-volt plug into your vehicle's power outlet.
Or...?
Frank Farmer
Long Beach, CA
aa.diver@verizon.net
http://mysite.verizon.net/aa.diver
PRETTY PENNY
'01 C-250 WK, Hull #558
Response Posted - 08/23/2006 :  06:22:15  Show Profile  Visit britinusa's Homepage
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Uses Less Amperage Than Your Car Headlights <hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
70W headlamp x 2 = 140 watts = 12v*11a I would hope it uses less!
I have a thermoelectric cooler in my office (small, holds 9 small water bottles, I'll check the amp draw today.
If the unit used, say, around 4amps = 48watts then a solar panel could run it.
Less amps the better for those of us that go out for 2+ days.
(Looking forward to our next trip on Labor day weekend!)
paul
Ericson33
Response Posted - 08/23/2006 :  11:59:43  Show Profile  Visit Ericson33's Homepage
I have been told that these new cooler refrig only keep the stuff inside cool around 20 degrees than the outside temp. So if its 90 outside then it will only cool to 70 deg. Most of these units are designed for in the car use, The cars a/c is running so it keeps the outside of the cooler at a lower temp. I myself have a cooler refrig, It was one of the first things I bought for our boat back 4 years ago. It is still sitting in the attic over the garage, and I have never used it. My brother also has one of these and used it on his speedboat pluged into the cig lighter, He was very disapointed with the results it put out.
Is there anyone that has used these?
Response Posted - 08/23/2006 :  12:09:13  Show Profile  Visit Champipple's Homepage
Anyone using a cold plate?
Response Posted - 08/24/2006 :  16:53:33  Show Profile  Visit aeckhart's Homepage
I recently received a - and I'm reading the back of the fridge, JH Fridge, model JH-7F, AC 120V 60hz, DC 12V at 0.75 amps. I had it running for two days while on a short cruise. About 10 hours of its use was on shore power. This is a hot and cold frig which has a 9"x8"x8" deep storage area. It worked fine with no appreciable battery drain. I have a solar panel and a 6 amp alternator on my motor and used both on the trip. I'll see if I still have the box if you need more info.
Tom Potter
Response Posted - 08/26/2006 :  11:17:49  Show Profile
Here's a [url="http://www.i-m-d.com/engel/main%20page.htm"]site[/url] with some interesting 12/120V Fridge/Freezers.
Dkn420
Response Posted - 08/26/2006 :  18:18:12  Show Profile
Those Engle's be expensive...but I hear they are very good. Dan #727
