Over the years I have not been able to successfully tweek the Rudder Gain & Damping settings on my Raymarine ST2000 Tiller Pilot so as to have the boat maintain a straight course. Gusting winds and/or running on a broad reach with following swells. Even after doing everything to limit weather helm as much as possible, the boat steers an embarassing S-Curve.
What combinations of Gain and Damping have worked well for those of you enjoying the Raymarine Tiller pilot?
Thanks in advance for any input you offer. This site continues to be very enjoyable reading.
Mark, I have an ST-1000, which isn't as powerful, but I think you're asking too much of the tillerpilot. They do a great job in moderate conditions. Following/quartering seas are always too much for mine, as are irregular gusts (is there such a thing as a regular gust?). The tillerpilot isn't as smart or as quick as you are -- when the seas are following or quartering, you have to anticipate tiller movements to keep the boat on course, and the tillerpilot can only react.
In those conditions, you will probably need to steer manually. Take some comfort that your intelligence and ability exceeds that of a machine!
I have a Simrad TP10 and agree with Brooke. Unless you are motoring with little or no wind, tiller pilots will not keep a straight course, particularly down wind. It steers the boat well enough in heavy air so that I can get away from the tiller for brief periods. When doing so I generally spill my main so there isn't so much pressure on the rudder. This limits rounding up which overwhelms the autopilot. Somtimes one has to sacrifice performance to achieve a desired effect particularly when cruising.
I have been playing with rudder preasure so I can learn how to steer the boat without one and I am supprised at how little rudder preasure it takes to hold a course if the sails are balanced. In the boat I have, it said to sheet in the jib and let out the main and the boat will head off. Let out the jib and sheet in the main and the boat will head up. So I figured there must be a happy medium. Now when I balance the sails, the rudder if finger light. Cheers.
