I am sure there are others with much more knowledge about this, but I think there are brake/clutch in the drum the might wear out. I do not have the problem you have but lately I have seen metal dust on the step below the drum after I winch up or down so I assume something is wearing out. Cheers.
This is one of those things you don't want to mess around with. You could probably remove and rebuild your winch, but for about $150 you can buy a complete new one. I'm a do-it-yourselfer and love fixing things but this isn't one I'd attempt. I don't think Catalina Direct sells parts for these winchs, just complete replacement units.
To add to the import of this crank, one of our local Clinton River Catalina Ass. member's crank let loose and the keel swung down and when it hit the stops, it cracked the fiberclass and he sank at his slip. It took about one minute to sink!!! He had full insurance and they totally the boat. Cheers.
Just in case -- make sure you're cranking the correct way. Right to raise, left to lower. If you crank the wrong way, the clutch won't hold, the crank will windmill, and if you try, instinctively, to stop it, you can almost break a finger. Guess how I know this?
If you're cranking to the right (clockwise) and you don't hear a clicking sound, then your winch is sick.
To bad you don't have a part number because it is probably a re-labeled Fulton braking winch and cheaper from Fulton.
Can't say with certainty, but on my Clipper it was a simple matter of lowering the keel to take the load off the cable (in water or on trailer), unspooling the remaining cable, and remove and replace the winch. Crank it back up. Dave B.
I agree with the advise given concerning replacing. One of the risks of a swing keel is the lifting winch. Lots have been written about this over the years. If the winch fails when the keel is up, the falling keel will do significant damage, up to and including sinking the boat. YOU DON'T WANT TO MESS WITH A DEFECTIVE KEEL WINCH. PERIOD. END OT STORY.
I have raced and daysailed from both sides of the lake. She is a gem to sail on. My first sail was there in a Flying Junior. While I am sure people have larger boats than ours, I think our 25s are the perfect boat for Hefner.
glad to see someone else enjoys shallow water and high winds . i'll look forward to possibly meeting you either on the dock (i'm slipped out of gate 11 out near the wall - and gulls) or on the water - when we get some! are you by chance any relation to a north from oc? frank, your most definately right about 25's being the perfect size for the lake. someone's got a new 30' out there and i've seen them already run a ground (glad i've got a wing - a swing would be better though like you've got david).
Don't you wonder how hull number 6 got to Oklahoma? I would think the first several hundred would be in southern California. As I recal Hull 1 is in Texas.
Ok, I got a new winch installed. Thanks for all the help. Why is everything harder than it seems...
I ordered the new winch and it came as promised from Catalina Direct. Once I had time, I went out to the lake to put it on. Seem easy enough. Just unbolt the old one, bolt on the new one and attach the cable.
I started to take off the old winch but found I needed an extender for my socket to loosen it. So off to Home Depot to get the extender. After a few days I was back at the lake to finish the job. Was able to use the extender to take of the old winch. Started to put the new winch on and found the holes in the mount for the new winch did not match the bolts comming through the step in the cabin stairs. Off again to Home Depot to get a metal drill bit to put holes in the mount that matched the bolts. I goot the holes drilled and the winch bolted on. Fought with the frayed ends of the cable to get the cable attached after a few pokes that drew blood, I got the cable attached. Started to put the winch together and found the new winch was a little larger than the old winch and it would not fit over the PVC pipe around the cable. So back to Home Depot to get a saw to cut an inch of the PVC pipe. Back to the boat, cut the pipe, and put the winch back together.
Finally ready to give it a try. Brought the keel up, but it would not stay. Bummer, that was the original problem. After some invesitgation, I found the the bolt going though one of the new holes was too long and was preventing the rachet from moving so it would not slip into the gear teeth. I was done(in more ways than one) for the night.
The next day I was of to Home Depot for the 4th time to get a hack saw,file and vice to cut the bolt off. Back to the boat to cut of the bolt. Took the winch off, cut the bolt, put it back on and was ready to try it out.
Success! I can now move the keel up and down with out fear of dropping the keel to hard.T
This was way to hard. This is my first competed project on my boat. I have several to go. I think I need to by stock in Home Depot.
That has been my experience too. Only had the boat for a year and a half, but nothing is ever easy when it comes to this kind of stuff. It always takes at least twice as long as you would think.
This is why I pulled the boat I waws given and took it apart to rebuild. It's apart now almost ready to paint, but we found where the keel had dropped with PO and getting ready to repair FG. It definitely is cracked. I didn't trust the old girl. I'm glad I never sailed her. She's old like me with need for some fixin' up. The SK pin was bent 3/8" when the keel dropped. I imagine much more and the keel would have detached altogether.
