We're looking at getting a bimini from Catalina Direct. The aluminum frame is about $220 less than the stainless steel. Most of our sailing is winds well under 20 kts, and if the wind did kick up we would fold it down. Has anyone bought the aluminum model and have comments on the durability? Also, would appreciate any input on the fittings - stainless steel v. nylon are the choices. We plan to keep the boat for 2-3 years so are wanting to be economical but not to buy something we will regret.
I bought an off the shelf bimini from Overtons last year. Mine is aluminum and I figured for half the cost of stainless steel and for my needs, aluminum would be fine. I asked a similar question when I was shopping around and many member here have aluminum. I think one of the main concerns is make sure no one uses the aluminum frame as a hand hold. It could bend and they might go right over board. If you planned to keep the boat longer term and were really into cruising, then maybe the stainless steel would be better, but for most uses, aluminum is probably fine. What type of rig do you have, standard or tall? Have you looked at the methods different members have used? I made some custom mounts that slide on the genoa track. If you need more details, just search for bimini install.
I agree with Justin on not using it for a handhold. We have an aluminum frame and it is just not as sturdy as stainless. On the other question, the nylon fittings have a habit of cracking and need replacement. That is on the list for this year on ours.
We exchanged emails with you a few months back and are just now getting around to the bimini after more urgent maintenance and upgrades. We do have a standard rig.
Plan is to get the kit and take it to the boat to see where it would fit best. Then I can make better sense of the comments on the listserve.
I am leaning towards aluminum and your message confirms that it is a reasonable choice for the way we would use it. Thanks for the input!
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by danc</i> <br />Most of our sailing is winds well under 20 kts, and if the wind did kick up we would fold it down. Has anyone bought the aluminum model and have comments on the durability?<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Dan,
I bought my TaylorMade clearanced aluminum framed bimini with nylon fittings in 2002 and I have not had any problems with it.
I wouldn't be overly concerned about having a bimini up in winds of 20 kts since biminis are designed primarily for powerboats with much higher apparent wind speeds. On two occasions, my bimini went through 50mph winds without batting an eye.
Just ordered the aluminum frame and nylon fittings from Catalina after confirmation from Mike and Don that the aluminum is not too flimsy for normal use. If aluminum holds survives Oklahoma winds it will thrive in the mild breezes we (usually) get on Puget Sound!
I'm a new C-25 owner and a 30 year C-22 owner. Two years ago we finally bought a bimini for the C-22 and went with aluminum frame and stainless fittings. wish we had done it years earlier. We bought ours online from Boatcoversdirect and have been very pleased. It was less than Catalina Direct and they included a sunbrella cover for it free. I'm hoping to use it on our C-25 also, but with a tall rig, I'm told we may encounter problems with the boom height. Good luck!
I also found Sunbrella biminis w/aluminium for less than $300. Anybody know the height from the coaming to the boom on a 250 SR/WK? How wide is the right width?
