 Garmin 172C GPS chartplotter Installation
Jmurfy
Initially Posted - 03/17/2007 :  11:03:07  Show Profile
Does anyone have a suggestion on the best place to mount a Garmin Chartplotter? ( http://www.garmin.com/products/gpsmap172c/ ) I have a 1985 C25, standard rig, fin keel. I dont know if my GPS has an internal or external antenna yet.
My problem is I dont want the mount protruding from the starboard cabin bulk head (where the knot meter and depth gage is located) since my wife usually is using that position as a back rest when we are sailing. (The mount stays fixed and the unit comes off when I'm docked.) Unfortunately thats the best place I can think of because power is already located at that position and I'm usually facing that way when sailing.
Response Posted - 03/17/2007 :  17:13:45  Show Profile  Visit Leon Sisson's Homepage
In placing navigation instruments, my suggestion is to plan on installing them where they will help the helmsman best (on both tacks and downwind or motoring). Then deal with other issues such as wiring, physical attachment, crew inconvenience, asthetics, etc. About the only other high priority consideration would be interference with sail controls or high risk of damaging the instrument.
As to interfering with using the bulkhead as a backrest, my intruments are mounted as high as practical to put them closer to the helmsman's line of sight. This leaves room below them for one of those square type IV PFDs against the bulkhead. The thickness of the PFD spaces the lounger out enough to keep the instruments from poking them in the back. (This does not however, prevent the lounging crew from blocking the helmsman's view of the intruments.)
-- Leon S.
djn
Response Posted - 03/17/2007 :  19:20:28  Show Profile
This is what I did and it was great. After tightening the arm and loctighting it, I never had to adjust it, just push it out of the way if I was trying to get in the cabin or out. I bought the arm from West Marine. Cheers,
Jmurfy
Response Posted - 03/17/2007 :  20:29:27  Show Profile
Wow, great idea Dennis!
djn
Response Posted - 03/18/2007 :  11:56:53  Show Profile
It works great in that location. My hatch boards were smoked plexiglas so when I was in heavy downpours, I'd swing the GPS/Fishfinder back a bit, put the hatch boards in and I could read it all through the smoked plexi. Cheers.
Response Posted - 03/18/2007 :  19:15:32  Show Profile  Visit Leon Sisson's Homepage
Dennis,
That's a great installation! The tranparent hatch board addresses one of my only reservations about swing mount instruments. Good job!
ct95949
Aruba
Response Posted - 03/18/2007 :  20:47:49  Show Profile
I just bought a Garmin 492 and was about to ask the same question. I had seen the mount that Dennis installed (and others) but it seems like the unit should be a little closer for the helmsman to see and operate. Because of the location of the moter, mainsheet and bimini I usually sit at the aft end or middle of the cockpit.
I've been toying with the idea of mounting a 2' piece of T track horizontally on the port locker just below the corner of the seat, then fastening the GPS mount to an old genoa car. Wiring would be easy into the side of the locker, the unit could be adjusted forward and aft and removed from the track when not in use. I don't think the track would be too obtrusive permanantly mounted in the cockpit. Any thoughts ?
Response Posted - 03/18/2007 :  21:35:26  Show Profile  Visit OLarryR's Homepage
Dennis - Nice hatch board ! What is the thickness of it and curious as to what you used to cut it ? Looks to be one piece - Where do you store it when sailing ?
Response Posted - 03/19/2007 :  13:50:03  Show Profile
BTW, it's not uncommon to make just the top hatchboard of plexiglass (or even better, Lexan) and leave the lower ones teak for a combination of light and privacy. A thick piece of Lexan can be routed to match the shape and overlap of an original teak hatchboard. There's a shop that does that kind of work in Norwalk, CT--probably others elsewhere.
