 Towing Bridle SOLD
existentialsailor
Initially Posted - 03/22/2007 :  15:09:34  Show Profile
It is designed to be used with boats having two towing rings on the bow tubes ... This gives the towing stability.
The 3,800 lbs. Test-strength red nylon webbing has built-in shock absorption which takes the strain off the towing rings.
A bright yellow float prevents the bridle from sinking and fouling props.
All hardware included is stainless steel; the towing ring, for attachment to your main tow line, and the two snap hooks for attaching to your boats' towing rings.
Bridle is 6' long from the towing ring to the snap hooks.
By attaching your own towing line to the towing ring and routing to both stern cleats, you will effectively be towing in an x' - type manner, which is the safest for your inflatable.
In very good condition, new last season.
$30
Contact: Use my forum name and add @gmail.com
Rick
Edited by - existentialsailor on 03/22/2007 16:42:57
