 Halyards, Lines and Sheets
sfrank
Initially Posted - 04/24/2007 :  22:28:19  Show Profile
I just purchased a 1986 catalina 25. I an trying to make it sea worthy in every way. I have evaluated all of the Halyards and sheets and made the decision to replace all. Last week i found a site that had complete sets of haylards and sheets spicific to the catalina 25 with whipped ends and fittings. I can't locate that again. Can anyone help with info---Thanks
Steve
Steve
Response Posted - 04/24/2007 :  22:34:10  Show Profile
Hi Steve! One good source is Catalina Direct (a third party vendor) at http://www.catalinadirect.com . I recommend getting their Owner's Handbook--about $10. It's essentially a catalog, but with many good ideas and information for maintaining and upgrading the C-25. They know our boats inside and out.
Welcome to the association!
Edited by - Dave Bristle on 04/24/2007 22:35:50
Response Posted - 04/25/2007 :  05:29:50  Show Profile  Visit Frank Hopper's Homepage
study Layline.com, be educated, don't accept someone else's priorities as your own. I would not want a made up set. Call Layline and visit with them.
Response Posted - 04/25/2007 :  08:10:57  Show Profile
Speaking of Layline, a month or so ago I was shopping for some line and saw Defender had Samson XLS Extra on sale. I went over to Layline to compare prices and found a peculiar icon for the Samson rope.
Weird, eh?
Response Posted - 04/25/2007 :  09:03:27  Show Profile
<br />...don't accept someone else's priorities as your own. I would not want a made up set.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Different strokes... (Either way, get to know CD as well--they're a good source for lotsa stuff.)
Response Posted - 04/25/2007 :  09:18:37  Show Profile
Might have been Cajun Trading.
http://www.cajuntrading.ca/catalina.htm#25
dblitz
Response Posted - 04/25/2007 :  22:03:33  Show Profile
I would be careful about what thickness jib sheets you get. I replaced the jib sheet for my furled 150 the same as was on the boat previously but it is too thick and sometimes, in low wind situations they pull the jib in too much.
Response Posted - 04/25/2007 :  22:16:32  Show Profile  Visit DaveR's Homepage
Great link Sloop, Joe. Didn't know about that one!
Response Posted - 04/26/2007 :  08:46:51  Show Profile
Note that if your lines are led aft to the cockpit (or will be), the main and jib halyards need to be 65' long. [standard rig]
Response Posted - 04/26/2007 :  09:16:58  Show Profile  Visit Frank Hopper's Homepage
I prefer 70'
Response Posted - 04/26/2007 :  14:05:46  Show Profile  Visit Leon Sisson's Homepage
<br />I prefer 70'
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Yup. I'd much rather handle a few extra feet than be a foot short when I need to reterminate a line. Those few feet make it practical to end-for-end your halyards about 1/3 to 1/2 way through their useful life, thus moving the high wear points, and extending the life of the lines considerably.
-- Leon S.
Response Posted - 05/04/2007 :  23:49:13  Show Profile
What thickness line do you guys use for the 150 genoa sheets (cruising and casual club racing) and how long should it be ideally?
David
Response Posted - 05/05/2007 :  06:18:47  Show Profile
<br />What thickness line do you guys use for the 150 genoa sheets (cruising and casual club racing) and how long should it be ideally?
David
I use a 3/8" line for my genoa sheet. As to length, ideally it should be long enough so the lazy sheet is still in the cockpit when the working sheet has been sheeted in all the way.
Renzo
Response Posted - 05/05/2007 :  07:25:29  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"> I would be careful about what thickness jib sheets you get. I replaced the jib sheet for my furled 150 the same as was on the boat previously but it is too thick and sometimes, in low wind situations they pull the jib in too much.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
If you are racing you might want to consider buying a set of light air sheets and a <i>Burton</i>(a reefing hook with a short length of line) so that you can change the active sheet back to your heavy sheets while sailing, without changing the trim on the sail, if the wind pipes up.
Edited by - Renzo on 05/05/2007 07:26:20
Response Posted - 05/05/2007 :  11:05:45  Show Profile
I have 5/16" lines on the 155% genoa and the 11% jib, but 1/4" lines for the light air 150%.
If you are using heavier sheets in very light air, it often helps to have a crew member hold up the clew of the genoa, which takes the sheet weight off the sail and enables it to shape in the light air.
Response Posted - 05/05/2007 :  12:07:40  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Renzo</i>
<br />...If you are racing you might want to consider buying a set of light air sheets and a <i>Burton</i>(a reefing hook with a short length of line) so that you can change the active sheet back to your heavy sheets while sailing, without changing the trim on the sail, if the wind pipes up.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Not being a racer and therefore putting more weight on safety than speed, I shy away from metal hardware on the jib clew. When the jib is flogging, a metal object can do damage to anything within its reach, including foredeck crew. Just my preference...
Renzo
Response Posted - 05/06/2007 :  08:10:07  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">have a crew member hold up the clew of the genoa, which takes the sheet weight off the sail and enables it to shape in the light air.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
I believe most racing rules make it illegal to do this
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">When the jib is flogging, a metal object can do damage to anything within its reach, including foredeck crew. Just my preference...<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
The burton is only installed temporaraly while the change of sheets is being made and keeps the sail secured so there is no flogging. In essence it is a safer way of doing things. But if you are not racing you can just change the lazy sheet and then tackand change the other sheet.
Edited by - Renzo on 05/06/2007 08:10:58
Response Posted - 05/06/2007 :  09:36:18  Show Profile
<br />...The burton is only installed temporaraly while the change of sheets is being made...
Sounds good--I hadn't seen that used. I have, however, seen people use something like a caribiner or snap-shackle on the sheet, which scares me a little... (Everyone's seen how a jib can start whipping in a strong breeze.)
Response Posted - 05/06/2007 :  11:14:00  Show Profile
Renzo - the racing rules DO allow this. The human arm is not an "outrigger". You are not, however, allowed to hold out a whisker pole attached to the clew - the inboard end must be attached to the mast.
Renzo
Response Posted - 05/06/2007 :  18:37:35  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"> the racing rules DO allow this. The human arm is not an "outrigger". You are not, however, allowed to hold out a whisker pole attached to the clew - the inboard end must be attached to the mast.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Derek - I may be wrong (I frequently am) but I was specifically refering to the C-25 anti hiking rule:
<i>J. ANTI-HIKING
General - While participating in Catalina 25 Class races no person while on board and while racing may position themselves in any manner which will extend their torso outside and beyond the vertical extension of the sheer other than temporarily.</i>
On a beam or downwind reach I am assuming that a person, with less than the reach of an Ape,would have to lean his torso out past the lifelines to have any benificial effect in overcomming the weight of the sheets in light air. But as I said before I am frequently wrong and I guess I would leave the decision to the protest committee.
Edited by - Renzo on 05/06/2007 18:51:26
