 Goof Off, Gelcoat, and Window Caulk
Cate
Initially Posted - 04/30/2007 :  20:11:44  Show Profile
When we were re-caulking the windows we got some of it on the surrounding gel coat. Can we remove this with goof off safely?
1983 C-25, Standard rig, swing keel
Response Posted - 04/30/2007 :  21:34:28  Show Profile  Visit Champipple's Homepage
I would think so Cate
glivs
Response Posted - 05/01/2007 :  06:00:22  Show Profile
Cate,
Gel coat should be no problem. If you try to remove caulk from your windows, however, the answer may depend on whether they are glass or not (Lexan, etc.). If glass, no problem. If not, I would cautiously test a small amount of solvent ("goof off" or "oops") in an unobtrusive area before proceeding to ambitiously. To remove sealant such as 3M's 101 before it has cured, rubbing alcohol and a little elbow grease makes a good start. Life Caulk also markets a product called "Release" that works great but is distributed only in 1 oz. containers. Alternatively, let the caulking cure and simply rub/scrape it off using your fingers, plastic putty knife, or (carefully) a razor blade.
