I was washing the boat, and somehow put a hole in it. It is at the forward starboard side of the hatch. It is about the size of a quarter, maybe a bit bigger.
Does it go all the way through? If not I'd get some gelcoat paste and smooth it on.
If it goes all the way through, I'd build up a couple of layers glass cloth and polyester resin on the inside. Fill in with small cut to shape pieces of glass cloth and resin on the outside until it was close enough to the surface for the gelcoat paste.
<b>Wait a minute! Wait a minute!</b> There <b>has got</b> to be more to this story than "I put a hole in my hull while washing the boat" I mean, I have scratched my gel coat by scrubbing too vigorously with Soft Scrub and a Scotch Brite pad, but putting a hole in the boat(especially a hole like the one shown in your picture)would require a super-duper, atomic powered, high pressure hose with an armor piercing nozzle.
Believe it or not, I was on my hands and knees washing the boat. I had a sponge in my right hand and I was (partially) supporting myself with my left hand. This hole was caused by my thumb on my left hand.
I am all but sure that in the 2 years I have had the boat, I must have walked on this spot before. I still am amazed it broke this easily.
I would guess that something dinged the hatch there, maybe just dropping the lid too hard, and caused the gel coat to crack. When he sprayed it there was probably just enough pressure to wash it loose. Looks like it just goes to the matt underneath. I've got a couple of those around the front hatch where I had to break in one time when I left my keys inside! Gotta fix that some day.
The fiberglass/gel coat is about 1/8 inch thick where this hole is. There is a space behind it of about 1/2 inch where I can see there is metal underneath. I assume there is a metal frame around the hatch.
Could this be an old air bubble between the gel coat and the structure underneath? I have seen several of these on my 25 and others, though usually only 1/4" or so in diameter. Usually they are on a corner, like yours appears to be. When the boats are made, the gel coat is sprayed on the female mold first. Then the glass mat, core, (metal?), etc. is layed-up by hand to build up the hull/deck, and air between the layers are worked out with a roller or brush. Sometimes these voids are caused by air bubbles trapped between the gel coat and mat that someone missed. They are not apparent until someone puts enough pressure on it to break through the gel coat into the old bubble. Does the surface underneath look smooth and shiny? This would indicate that it was an air bubble introduced at the factory. If it is dull and jagged, then it is some sort of impact damage. You can fill it with gel coat or Marine Tex and sand smooth, and you should be ok.
If you're seeing metal behind it, is this a mounting point for a piece of hardware on the inside, like the hatch dogs or the sliding hold-opener thing? [i(Pardon my lack of vocabulary[/i]
Might need a proper fix like my second suggested method.
The air bubble theory sounds correct. I've drilled or sanded down several thin spots in the gelcoat that had a cavity beneath. These thin layers seemed fragile with nothing behind it.
I have a dozen or so of those on my boat. It is merely an air bubble in the layup. Just get some marine-tex or other filler material and sm0oth it out.
You might want to bevel the edges and the cracks running away from the hole, then fill it with thickened polyester resin nearly to the top and finish out with gelcoat paste.
You're not going to be able to get to the other side of it without cutting into the cabin liner, so just fill it.
I can't think of anything metal that would be behind that point. The closest hatch hardware would be the starboard latch plate a few inches away.
Marine-Tex. Make sure you get the white. I'm a big fan of this product because its easy to use and the finished repair looks good. The key being - that you sand it when dry, giving you exactly the shape you need. Color won't be exact, but it will be close, and you can texture it if on a stepping surface.
I too had about a dozen of these. I did what others mentioned. I filled with resin and let harden. I made little pockets or cups with tape to hold the form. I, however, couldn't figure out how to fill it "just enough" to allow room for the gelcoat. Especially if the hole was on a bulkhead or along the gunwal (sp?) or rub-rail. I overfilled it slightly and dremmeled it out to allow room for the gelcoat.
I'm sure there are other ways people have found.
I keep finding these little holes when polishing. You can also hear them if you thump the gelcoat.
