 Hydrauic Brake Actuator
Tom Potter
Initially Posted - 05/18/2007 :  19:16:02  Show Profile
I've been getting my trailer ready for some upcoming road trips. Replacing tires, bearings, etc. During my inspection of the brake system I found the Atwood brake actuator piston had rusted up again. I rebuilt it a few years ago and put a new master cylinder in. It appears the Atwood master cylinder is prone to rusting easily, no matter how hard I try to rinse the trailer after use. So this time I plan to try something different. I found this [url="http://shop.easternmarine.com/index.cfm?fuseaction=catalog.prodInfo&productID=5543&categoryID=150"]Brake Actuator[/url] made by "Tie Down" that has an aluminum master cylinder. Has anyone had any experience with this type actuator?
1997 250 TR WK (sold)
1984 O'Day 28 (sold)
1979 SISU 22
Bath, NC.
Response Posted - 05/18/2007 :  19:50:35  Show Profile
I have one of those except in the model designed for drum brakes. (they are different, make sure to get one that matches your brake type). The Tie Down 66 works fine, but if I had it to do over again, I'd opt for a heavier-duty 7,000 or 8,000lb rated model that has a coupler for a 2-5/16" ball.
They take a pretty good price jump going to that range, but IMHO peace of mind while towing is worth a boat unit.
Edited by - ClamBeach on 05/18/2007 19:53:18
Tom Potter
Response Posted - 05/18/2007 :  20:07:14  Show Profile
Bruce, the one I bought is for a drum. I chose the wrong picture for the post. It looks like a good unit. I thought about the larger size, but having to replace the tires and bearings too I was starting to get that stare!
Response Posted - 05/18/2007 :  21:16:06  Show Profile
Tom... they also have some actuators made of carbon fiber. My master cylinder and wheel cylinders were in bad shape at the beginning of the third sailing season.
I flushed all the old brake fluid, rebuilt the wheel cylinders and bought a new master cylinder and refreshed with dot 5 synthetic fluid and the system has remained free of rust since. Regular brake fluid is a sponge to water. The day to day heating and expansion and drawing in of fresh air brings moisture with it. The only way standard brake fluid can work is with a closed system having a bladder cap but even so it is still not worth fooling with... it is too easy to purge the system when rebuilding and go synthetic.
sweetcraft
Response Posted - 05/19/2007 :  00:53:43  Show Profile
Yes to everything above. Tomorrow the new disc brakes will replace the drum brakes and have the synthetic brake fluid to finish the installation. Will take pictures and give the #'s. Did use the drums for 26 years but only once in salt water (San Diego). Going North to the San Juans with the new brakes. The surge system is a #10 Titan, a 2 5/16 size, 10,000lb capacity which came with the EZ-loader. All of the parts are still available and include the master cylinder for disc brakes. Yes I also was getting the stare so only one axle this season.
Response Posted - 05/19/2007 :  13:36:27  Show Profile
C'mon guys, you cannot fall to "the stare" so easily! And this is for trailering safety!! You need to respond with "Honey, I want to make sure we are safe on the highway. I'm giving up some new boat items so that we can have this extra safety on the road."
If you give in to the stare for trailer brakes what happens when you want a big new improvement to the boat??
You represent all of us. Make us proud!
sweetcraft
Response Posted - 05/19/2007 :  22:22:18  Show Profile
Well, it's those questions that accompany the stare. Didn't the drum brakes work well all this time? Why do you need two axles with brakes? I do want a good budget for the trip.
stampeder
Response Posted - 05/22/2007 :  22:04:23  Show Profile
BC now requires brakes on all axles.
I've been happy with my single axle surge drum brakes, but will have to put brakes on the second axle before I haul back over the mountain to the San Juans and Vancouver Island.
I'm going to stick with the surge braking system, and put discs on both axles.
sweetcraft
Response Posted - 05/23/2007 :  00:12:38  Show Profile
Wonder if we come on up on 5 that we would be stopped. The manufacture put on the first axle only. It must be a requirement of both axles for the weight and on new trailers. How do we find out?
