Well, as long as I'm changing out the brakes I might as well switch over to LED lights for the trailer. My regular lights don't seem to appreciate getting submerged for long periods of time.
Has anyone done this conversion and have a recommendation for the LED components? Thanks.
I used to have problems with my trailer lights. One day I got to looking at the lights and noticed that the lights have a male/female plug in the wiring harness about 10" up from the lights. Then noticed the lights are fasten to the trailer with wing nuts. Finely the light bulb in the head went on. I now just unplug the lights and spin the wing nuts off and set the lights in the bed of the truck before I launch. Yes its another thing to do, but takes all of about 30 seconds and I haven't had a problem in years.
When I do need to replace them I definitely would go with the LED's.
That's exactly what we do. The PO showed us that part of the process, we just store the lights in our truck box till it's time to get back on the road.
Sorry Randy, no good suggestions, we haven't had the problem yet.
It hasn't been the lights that have failed on our trailer (2years old), it is the earthing points!!! Now before and after each launch, I spray the earths connections on the two tail lights with WD40 hoping it will help.
So, let's look at this light removal idea. How do you handle the two side fender lights and the three light bar across the rear of the trailer? Do they disconnect and get removed as well? Only my two stop/directional lights have wing nuts.
Maybe I can use this light removal technique to show the Admiral how frugal I am.
If earthing is a problem, run a dedicated earth line to each light. use solderless splices, put a dab of silicone and then heat shrink it. It should last for years.
