 Ouch
Initially Posted - 06/07/2007 :  10:02:06  Show Profile  Visit delliottg's Homepage
I finally gave up on Catalina and ordered the T-ball keepers for my shrouds from [url="http://www.rigrite.com"]RigRite.com[/url]. Part number [url="http://www.rigrite.com/Spars/SparParts/Tangs-complete/T-Ball_Backing_Plates.htm"]742-6[/url] for my TR mast.
Six shroud retaining plugs: $12 ($2/ea)
Shipping to Washington State: $14 (<i>you've got to be kidding me, they weigh maybe an ounce each?</i>)
Knowing my shrouds will stay in place as I raise & lower my mast: Priceless
David
C-250 Mainsheet Editor
Sirius Lepak
Response Posted - 06/07/2007 :  10:28:16  Show Profile
Nice web site but no pictures which is too bad.
Maybe they were considered hazardous shipping - we know how you TR sailors are.
Edited by - Nautiduck on 06/07/2007 10:28:36
Response Posted - 06/07/2007 :  10:43:44  Show Profile
I'll tell you what's priceless...Knowing that your leeward shrouds will be there when you tack!
Response Posted - 06/07/2007 :  11:03:47  Show Profile  Visit delliottg's Homepage
Good point Don, although under tension they're not <i>likely </i>to come out (crossing my fingers). I'm only missing one for the "real" shrouds as opposed to the baby stays, but my port inner likes to pop out just as we're raising the mast which can be...disconcerting. I've learned to keep some tension on it as Rita cranks the mast up so it can't pop out. Shouldn't have to do that anymore once these show up in a few days.
I tried to find a vendor closer to here to purchase them from, but the only vendors I could easily locate were in the UK, and I've already been bitten on Ebay buying stuff from there & paying 3-5x what the item cost for shipping.
frog0911
Response Posted - 06/07/2007 :  14:09:01  Show Profile
My dealer did not use them when we raised the mast on PennyII. I did not know there was such a thing. What he did was insert the them into the holes pull them down against the mast and tie six pound fishing line around were the wire meets the hook. As we raises the mast and the stays went tight, pulling away from the mast it broke and all stayed in place. I have only dropped my mast once since then, but used the same procedure and it worked fine. Since then I found three of the little black plugs in one of the baggies he gave me. Maybe the next time I go up the stick, I will insert them in the uppers.
ct95949
Aruba
Response Posted - 06/07/2007 :  16:26:57  Show Profile
T-ball retaining plugs
Response Posted - 06/07/2007 :  16:29:44  Show Profile  Visit delliottg's Homepage
Hah, well three was all I really needed...should have made a deal with you.
We haven't had any problems when dropping the mast, but nearly every time when we raise it I'll find the port inner shroud has dropped into a neat coil inside the cabin.
Yes, they're T-ball retaining plugs. If you're looking for them you need to measure the inside dimensions of the backing plate (mine were 15/16th x 1/2) to determine which ones you need.
Edited by - delliottg on 06/07/2007 16:30:51
