 Capri 25 Specific Forum
 another new owner
jm011602
Initially Posted - 09/20/2007 :  22:17:51  Show Profile
greetings everyone,
my wife and i have just acquired our capri 25 which has been sadly neglected. we hope to be working on it over the next few months to get it ready for spring 2008. not knowing too much about the capri 25, we are hoping we can get much needed help through this forum. joe
jm
Ericson33
Response Posted - 09/21/2007 :  00:26:43  Show Profile  Visit Ericson33's Homepage
welcome joe
if you have any questions feel free to ask the group
jm011602
Response Posted - 09/21/2007 :  09:04:33  Show Profile
thanks much. may i ask what could be the first of many questions as to what four stroke engine size i should get? we will be day sailing most of the time on lake michigan out of winthrop harbor in illinois. joe
joearcht
Response Posted - 09/23/2007 :  20:05:51  Show Profile
Hi Joe,
I have a Nissan 6 hp. I sail on a small lake (relative to Lake Michigan) and I feel the my motor is overpowered for this boat. I'm thinking of trying to downsize to a 3 or 3.5 hp. But you might need more hp to fight the wind and current where you sail, so I'd suggest you take the advice of another Lake Michigan Capri sailor.
Also, I've read somewhere that the Capri 25 stern is "weak". I know that where my outboard bracket is mounted the stern has alot of "flex" and I'm leary of applying too much thrust to it. I'm going to research a way to reinforce this area when I get time.
Regards
jm011602
Response Posted - 09/23/2007 :  20:40:12  Show Profile
thanks for the input, joe. i had planned on putting a 5 hp outboard, but i was advised to put a bigger one to handle strong headwinds.
re the weak stern, one of the members had posted some info on reinforcing the transom. i am thinking of opurchasing the steel plate he has avaailable for this purpose. joe
Ericson33
Response Posted - 09/23/2007 :  21:22:42  Show Profile  Visit Ericson33's Homepage
I have a 4hp 2 stroke on the back of our capri 25. I think the power is just right for this boat, I would suggest that you get the long shaft, I had a short for about 1 year, and it would come up at times. We are on a smaller inland lake, but we tend to get larger white caps becuse of the narrow channel. I have yet to see our transom flex because of the motor? I will have to check it out. The PO might have re-inforced this before I bought the boat.
jm011602
Response Posted - 09/23/2007 :  21:40:48  Show Profile
just came back from the yard and decided i need to replace the compass, depth gauge and knot meter. may i ask for suggestions as to what and where i can purchase suitable replacements? thanks. joe
jm011602
Response Posted - 09/23/2007 :  21:42:37  Show Profile
Ericson33
Response Posted - 09/23/2007 :  22:32:01  Show Profile  Visit Ericson33's Homepage
Compass - What kind? What size hole? Where is it located at?
I would look at the Contest® 101 tactical compass
http://www.plastimousa.com/compass_tactical.htm
Again for the Depth and Knot Meter - What are the size holes? Where are they Located at?
What are the size of the thru Hull's?
There are a ton of options out there.
My knot meter and Depth are Standard 150 line that I have just seen are discontinued :(
Nothing beats the air on your face :) and it's free
Get a good GPS or a Velocitek
http://www.velocitek.us/
existentialsailor
Response Posted - 09/24/2007 :  07:58:47  Show Profile
I've been happy with Raymarine equipment.
jm011602
Response Posted - 09/24/2007 :  09:38:10  Show Profile
i was thinking of replacing the ones that came with the boat with the same equipment, if they are still available.
