 leaking lazarettes
dwadle
Initially Posted - 10/18/2007 :  08:18:03  Show Profile
I have a 2005 250 wing keel, and the cockpit lazarettes are always full of water. Has anyone had this problem? Is there a way to drill a hole so the water will drain?
dmw
david m. wadle
Response Posted - 10/18/2007 :  08:49:59  Show Profile  Visit delliottg's Homepage
My '97 has the same problem, I've been deliberating on how to fix it, but drilling holes doesn't seem like an option. Holes in the cockpit lockers would have to drain somewhere other than directly off the boat, which pretty much means the bilge. I suppose you could plumb drain lines between the cockpit bulkhead and the interior of the lockers, but that seems prone to leakage to me. So far the only time I've seen water in my bilge is when I put it there to test my pump, I'd like to keep it that way. I'd rather keep water out of the lockers in the first place.
I've been thinking closed cell foam gaskets to fill in around the insides of the lids where they don't quite make contact with the rims of the lockers. I'm open to other ideas that don't involve drilling.
Has anyone solved this problem? We keep mostly water proof stuff like footpumps, fenders, winch handle, etc. in them but would still like to keep them dry.
Response Posted - 10/18/2007 :  08:56:30  Show Profile
Mine are dry. The PO put foam gaskets like David mentioned on the lids. Try that before you start the drill.
Response Posted - 10/18/2007 :  09:35:44  Show Profile  Visit delliottg's Homepage
John,
Are the gaskets on the lids or on the locker rims? Can you tell me how thick they are?
Response Posted - 10/18/2007 :  10:45:33  Show Profile
They're on the lids at the point they contact the rims. Frankly, I haven't given them much thought but I think they're about 1/4" x 1" foam. The kind of stuff you'd buy to insulate your old rickety windows in a 70 year old house..... Sure why'd ya have to make me think of that project!!!!
Edited by - John Russell on 10/18/2007 10:46:27
Response Posted - 10/18/2007 :  12:36:27  Show Profile  Visit piseas's Homepage
I have an 03 and had leaking as well. Per past members help, I went to home depot and got the thickest foam they had and removed the old stuff and put on the new stuff on the lids. Now no more leaking. yeah. Good luck.
