I noticed the varnish has worn off my tiller. Now that the boat is out of the water I was thinking of revarnishing it as a winter project. I have redone the teak on the boat but I am guessing the tiller is not teak and it has a different look all together. Any suggestions what to apply to it after I strip the old varnish? Thanks.
Charlie McKitrick Norwell, MA Valiant Lady... for now '81 C 25 SR/FK
HELMSMAN SPAR URETHANE(Clear Semi-gloss) made by MINWAX. It has UV protection, moisture prrotection and is ristantant to extreme temperature changes and it is available at most hardware stores. I used this stuff 7 years ago, it still looks good and is easy to apply.
Make sure the tiller has not started delaminated before you waste your time and money on revarnishing. I always error on buying new vs rehab the old on such a critical piece of equipment.
I just noticed Catalina Direct sells new tillers for only $90. I guess if I see the slightest sign of rot or wear it might be worth my while just buying a new one.
I'll toss in a second for Helmsman Spar Urethane, four coats using the foam throw-away brushes, with light sanding between each one using steel wool. Gives a really smooth strong finish. Also good for main hatch boards if you make your own.
