 Removing teak
NCBill39
Initially Posted - 02/09/2008 :  23:29:50  Show Profile
I have searched the forums for some guidelines on removing the teak trim on my '86 C-25. The companionway guides for the drop boards are broken, and I want to replace them. I assume they are glued on, but have no idea how to remove them without damaging the fiberglass underneath or destroying the original teak which I hope to use as a template for the new stuff.
Response Posted - 02/10/2008 :  10:56:31  Show Profile
"I assume they are glued on, "
Probably not 'glued' more likely set in some sort of 'bedding compound'. The compounds used by the Catalina factory on my early model allowed me to remove all the trim without breaking a single piece.
However, bedding compounds vary in their adhesive properties and if they have been re-bedded by a previous owner you don't know what you're up against. If they are bedded in a strong adhesive like 5200 they may be very difficult to get off without breaking them.
Your options in a nutshell:
1) Very careful prying with one or more thin tools. Start on one end and gently work your way along.
2) Starting a piece of music wire underneath one end and using it to saw out the bedding compound.
(use it like dental floss under the piece).
3) Heat. Even 5200 releases when heated to a certain temperature. However, when using a heat gun you have to be careful not to damage the boat... or set it on fire. :>)
4) Chemical agents. There are 'release agents' available in the marine catalogs.
You'll be surprised how well 'ugly' teak looks after some sanding and re-finishing.
Response Posted - 02/10/2008 :  11:01:29  Show Profile  Visit Frank Hopper's Homepage
I think the "trick" that surprised most who did this is that there are screw heads hiding under the trim strips inside the companionway. and those pieces must be removed first before you can get the outside off.
Response Posted - 02/10/2008 :  12:25:13  Show Profile
Correct. It took me some prolonged sluething to figure that out--I wasn't smart enough to just ask here. I'm surprised you didn't find that by searching--it's been pointed out by me and others in numerous threads on the subject. But that's why we have the forums--no question is disallowed or ignored just because it was answered previously.
NCBill39
Response Posted - 02/10/2008 :  22:44:46  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Frank Hopper</i>
<br />I think the "trick" that surprised most who did this is that there are screw heads hiding under the trim strips inside the companionway. and those pieces must be removed first before you can get the outside off.
That is what I suspected, but then, it is evidently necessary to remove both the internal trim strips to get at the external strips and then the external strips. UGH.
If the teak were just ugly, I'd find a way to clean it up, but it is broken and the drop boards can come out.
2far2drive
Response Posted - 02/11/2008 :  09:51:10  Show Profile  Visit 2far2drive's Homepage
Mine is the exact same way, I dont even lock the hatch because the top board slips right out anyways so the lock is useless. Let me know what you end up doing to replace them as Im quite interested myself.
Response Posted - 02/11/2008 :  13:21:07  Show Profile  Visit Frank Hopper's Homepage
The outer teak is a very complex piece of wood, and very expensive to replicate. The 89s use a different strategy, a simple board.
I would look into changing the way your crib boards work and see if you can make something out of simpler pieces of wood.
Response Posted - 02/11/2008 :  13:38:24  Show Profile
For those of you with hatch boards so loose you can push/pull them out without sliding them up, you can put adhesive backed foam door insulation inside the slot to take up some of the slack. It not only centers them in the channel but stabilizes them so they do not move left and right. Cheap and easy.
NCBill39
Response Posted - 02/11/2008 :  21:35:00  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by 2far2drive</i>
<br /><blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">
I didn't mention it earlier, but there is a complicating factor - the width of the slot for the drop boards is about 1", but it appears that someone thinned the edges of the drop boards to about 1/2", so that one board can slip over the one below it - another reason to fix the guides. I don't think that replicating them will be too bad - my son-in-law is skilled with wood, so getting them to look nice shouldn't be a problem - even if they aren't exactly the same as the original. I bought my teak from EastTeak in South Carolina for about $13-$14 per board foot. My cost for materials is around $40.
