Nice photo. Tell us more about the mainsheet set-up. Can you adjust at the traveler as well as the boom, or just at the boom? I've seen slightly different set-ups on C-22's where they do gross trimming at the boom and fine tuning at the traveler.
Upon closer examination of the picture, I can see the error of my question. His mainsheet starts at the becket under the block at the end of the boom, and although it looks like he has a fiddle block with cam on the traveler, it appears that he is bypassing the cam. I withdraw my question!
This is the same set up that most of the C-22's use when they are racing, the only thing they do different is that they can also sheet in their mains at both the top and bottom blocks somehow.
wmeinert: ...they can also sheet in their mains at both the top and bottom blocks somehow.
Following the picture above, the main sheet would run from the mid-boom swivel cam through the smaller block under the end of the boom, down to the upper sheave on the fiddle block, then up to the larger single block hanging on the tang at the end of the boom, then back down to the lower fiddle block sheave and through the cam. Ignore the beckets. This allows more pronounced adjustments on the main from the mid-boom line, and smaller, more precise adjustments under heavier loads using the main at the traveler end.
Steve, I think the tether is a good length but, I can't for the life of me figure out the connection to the boom. A short (2 metre) tether will keep you on the boat. A longer one will keep you connected but potentially alongside or trailing behind.
