At first glance, that seems like a goofy question, but what I am trying to find out is what to set the depth sounder to. The specs say I draw 2' 8" with the keel up and 5' with the keel down. With the transducer mounted in the bottom of the hull, beside the keel box, what should I set the sounder to? I think that 2' would be about right but what is best practices? Does the sounder get set to indicate depth below the keel or depth below the surface or somewhere in between? Thanks, Ed
Ed HisHorse 1979 SR/SK #1393 Green Cove Springs, FL
You're looking for the 'keel offset' right? That corrects the sounder to read 'true depth'... based on the water surface.
At any rate, 1.5' is what I use for the offset on my swing keel. (Determined by looking while having the admrial hold up a tape measure alongside the hull.) For practical purposes, I think either value would work ok. If you're down to worrying about a couple inches of depth you're probably already too shallow anyway.
I'm getting older, and I think displaying depth below the keel would just confuse me. I too like the actual depth. The surface offset you use isn't really critical, just be sure it is at least equal to the the depth of your transducer. You never know exactly how deep the water is; mounting angle, heel,waves, and instrument accuracy are all variables that you don't control and affect readings. If you think it is at least 2 feet, call it three and be safe.
