<font color="blue"><font size="4"><font face="Comic Sans MS">Kim It's a lot easier tacking now that I've added these foot blocks for foresail sheet lines.... it's tamed those sheets and allows me better balance while I'm attaching line to winch. I need all those neat things for sailing single handed. Why does Catalina has them on larger boats...but not the C310?
These are Lewmar blocks..... 2500lb Safe Working Load w/ 3/4" ext plywood and good old 5200
Port plan
Port elev
Port below
Starboard plan
Starboard elev
Starboard below
paulj</font id="Comic Sans MS"></font id="size4"></font id="blue">
<font color="blue"><font size="4"><font face="Comic Sans MS">Steve I don't see a problem using the cutting board if it is thick enough. You can use the Tom Hanks strength of materials 1A test....cut out the size that you will be using and see if you can bend or deform it using your hands only. Some times using off the shelf items seems strange but saves time shopping around. Before using, remove cutting board label.
<font color="blue"><font size="4"><font face="Comic Sans MS">Yes Kim I would have routed the corners of the backing blocks and painted them. I'm not the craftsman I once was. I gave all the woodworking tools to the kids when we moved and all I have now is a micrometer, chalk and an axe.
Although it may be due to the line being slack, but if the line contacts the coaming between the foot and sheet blocks, you may want to add a rubstrake to prevent wear to the gelcoat.
Steve - The load there is lateral not vertical. You could probably use a newspaper. Just kidding, washers alone would be fine there though.
Starboard would work there. I picked up some old oak, routed the edges and stained it nicely. We cut off the bolts fairly tight and rounded them over to make a nice look on the interior.
Don, I read somewhere that it's best to have the hook part of the lifeline gate at the aft end of the line so that the lifeline doesn't risk hanging over the stern.
