 Wheel steering
n/a
deleted
Initially Posted - 08/21/2002 :  19:15:00  Show Profile
Gentlemen, Ladies...I am in need of your attention (help). I have a 1995 c250 WB, with wheel steering, up untilnow I have had the 2nd generation beaching ( kick-up) rudder. I just finished attaching the 3rd gen hopefully final newest wing ding rudder. Sitting at the dock, I turned my wheel left and right proudly feeling the sweep of the the pretty new rudder. Whilst doing so, I noticed that the wheel was turning with a great deal of resistance. I removed the rudder bracket so I would only feel any resistance in both the cable and pedestal.....stilll very tight. I looked behind the rear battery at the fixed end of the cable and noticed a little pile of black powder under the end of the cable. Upon further examination, I noticed that the cable is (Factory) clamped into a hard 90 degree coming out of the bottom of the pedestal, and another hard 90 degree turn as it passes thru the panel in back. I'm sensing that the severe bends in the steering cable has caused it to wear prematurely internally, and the evidence of that wear is piling as black dust on the floor. Have any of you noticed growing difficulty in turning the wheel, wear on the cable. And is there any way to lubricate this cable with or without disassembly.
Response Posted - 08/21/2002 :  19:32:25  Show Profile
I noticed that when I was helming Steve Steakley C250WB it felt like I was turning a barn door (compared to a 2-finger touch on my C25).
Derek C25 TRFK #2262
Response Posted - 08/22/2002 :  17:24:04  Show Profile
The rudder needs balancing...see the tech tips for instructions.
Arlyn C-250 W/B #224
n/a
deleted
Response Posted - 08/22/2002 :  18:09:22  Show Profile
Arlyn, and others...I followed your tech tip 2 years ago, and balanced the rudder (Ground the aluminum frame which of course allowed the beaching rudder to pitch forward), not the problem...I just installed the 3rd gen rudder, not the problem. I unhooked any connection to the rudder just to check the tension of the pedestal and cable.....tighter than dicks hatband , extreme tension thru the cable, and like I said there is a few tablespoons of powder under the cable end, indicating that something is grinding away the internals of the cable. I called Catalina, talked to Dave ( I often do).
He had me call Edson.....Edson replied that the earlier models 95-98 had the single cable wheel steering. He said many of them failed because the single cable was insufficient. Also the cable manufacturer is out of business, and no one is making that cable anymore. Not on the face of the earth. Ed at Edson recommended their retrofit system which is simply a double cable push pull set of cables which is the exact unit used on 99-2003 c250's. Cost $491.00. Ed said the price was adjusted to be low because many of us have complained about the single cable system, and that he has helped dozens of you retrofit your older 250's . He also sent me a parts list and said I may be able to buy the parts cheaper at one of their discount distributors. I'll let you know. Has any one "retrofitted" you older 250 to the newer 2-cable system????
