 hatch and lock
stampeder
Initially Posted - 04/20/2008 :  12:34:27  Show Profile
I've sanded all my exterior wood and have stained with teak oil. This picture shows that my hatch woodwork has yet to be stained and got splashed - we were sanding and the wind picked up, so what's a boy to do...he goes sailing and leaves the woodwork for another day.
ummm, where was I. Oh yes, my hatch-slider woodwork is ugly and I hate that nasty cheapo lock and I despise that piece of canvas that hangs down below it to cover the gap between it and the top crib board.
So, the question is: How do I fix up the slider woodwork - does it need to be replaced, what kind of lock do you have, where is your lock. Also, I will probably put high quality rubber door seal (weather stipping) along the bottom edge of the slider wood and if that doesn't work nicely, I'll buy new crib boards.
I looked through Catalina Direct but did not see a replacement for the slider woodwork - not sure what the actual name for it is.
willy
Response Posted - 04/20/2008 :  14:01:49  Show Profile
I have switched to a combination lock for my boat. Ever since I had to go to the marina office and borrow the bolt cutters when I locked my keys inside....
Willy
Response Posted - 04/20/2008 :  15:11:25  Show Profile  Visit OLarryR's Homepage
Mike,
Looks like you have hooked onto yet another possible area for tweaking - The lock and gap issue with the companionway boards. I have really not paid too much attention to this area. I just use a plain brass key lock. MY boards do not have a flap of sorts but the slit/opening is at an angle so it prevents most water entry, if not all.
From what I can see of the top of your boards, it seems a bit different than mine. I do not have what appears to be a wood handle (in your photo). What I usually do to bring the hatch in-line with the companionway boards is to slip the lock ubolt into the hatch lock ring and pull the hatch closed. Then I take the ubolt off the lock ring, close the metal latch over the lock ring and then secure it with the lock.
Response Posted - 04/20/2008 :  16:11:23  Show Profile  Visit Frank Hopper's Homepage
I added the handle to my 89, use a brass combo lock, am OK with the Perko hasp, and advise friends with hatch gaps to look at the foam weather strip sold for garage door bottoms.
Steve Blackburn
Response Posted - 04/20/2008 :  20:08:11  Show Profile  Visit Steve Blackburn's Homepage
No more ice on Ghost Lake? I gather you sailed last weekend.
stampeder
Response Posted - 04/21/2008 :  10:06:25  Show Profile
unfortunately, that is a stock photo. Taken Oct 2007.
