 Pinstriping on the Hull???
Old Disco Queen
Initially Posted - 05/07/2008 :  20:35:56  Show Profile
I am tired to the "brown" stripes on the side of my new boat...
Has anyone used that "Pinstriping Tape" on your boat?
I have my boat put in with the "strap-hoist" method...would this screw up the tape???
Stephen
Stephen J. Moore
quilombo
Response Posted - 05/07/2008 :  20:42:34  Show Profile
nah,, it will be ok, I have automotive striping on mine and its on there good
Old Disco Queen
Response Posted - 05/07/2008 :  21:14:53  Show Profile
Did you "strip" the wax off the hull before application? What did you use?
quilombo
Response Posted - 05/07/2008 :  21:31:10  Show Profile
just use some mineral spirits and then wipe off all the residue, and apply the pinstripe, it goes on pretty easy, just got to have a good eye to make a straight line, mine is just below the rub rail and it looks nice, its a series of black pinstripes getting progressively smaller in thickness about 5 lines
Old Disco Queen
Response Posted - 05/07/2008 :  22:16:30  Show Profile
Mine also has a rather large (4"-5") strip at the water line...did you put a strip on there?
stampeder
Response Posted - 05/07/2008 :  22:49:49  Show Profile
If its one of these stripes, these are called boot stripes and are painted on. a one quart can costs about $20. I used Brightsides by Interlux. I prefer it to vinyl or pinstriping because it can be repaired fairly easily if damaged. this is one of those things where you need to have your own stategy - if you are good with vinyl - it will give you good results as well.
quilombo
Response Posted - 05/08/2008 :  19:00:36  Show Profile
yes I do have one at the wateline, but its just to even out where the black and the yellow come together, you dont notice it because its black and it laid it directly inbetween the two colors for a clean look
