 motor walk
knightwind
Initially Posted - 05/19/2008 :  21:11:21  Show Profile
Jeez! I go to back out with rudder and motor hard to stbd and the aft swings out to the port...made me look stupid in front of lots of May 24 spectators...Are there any tricks?
Peter Keddie
Turkey Point, ON
79 Catalina 25 Fixed Keel #1050
Response Posted - 05/19/2008 :  21:20:56  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by knightwind</i>
<br />Jeez! I go to back out with rudder and motor hard to stbd and the aft swings out to the port...made me look stupid in front of lots of May 24 spectators...Are there any tricks?<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Yup. Give a burst to get you going (with the motor turned slightly to pull you to starboard), and then idle down. When the motor is trying to make the boat accelerate, in reverse it pulls the stern to port, and in forward it pushes the stern to starboard (turning the boat to port). It's commonly called "prop walk". If you idle down so you're coasting, the keel and rudder can do their things. (If you have a swing keel, it's best to have it down.) Also, when backing, a momentary burst in Forward with the motor turned the other way to push the stern around, can virtually make you pivot on your keel.
Another thing: Don't push the tiller all the way over close to 90 degrees--there it acts more as a brake than a rudder. If you limit yourself to about 45-50 degrees, the boat will turn as sharply as it is able to, which is pretty sharply.
(May 24... are you imagining things, or is Canada that far ahead of the US?)
Edited by - Dave Bristle on 05/19/2008 21:28:35
Response Posted - 05/19/2008 :  21:21:20  Show Profile  Visit Frank Hopper's Homepage
A rudder is seldom held more than 45 degrees, after that it turns into a brake. A sailboat only behaves when moving, get it moving before you begin turning, feel the turn, it is about net forces.
knightwind
Response Posted - 05/19/2008 :  22:02:59  Show Profile
<br />[quote]<i>Originally posted by knightwind</i>
We always call the long weekend "May two four" ... eh!
Response Posted - 05/19/2008 :  22:34:51  Show Profile
I always shove off when first backing up out of the slip. It gets me going and I'm able to adjust the position of the boat relative to the dock with a slight push or pull.
Response Posted - 05/19/2008 :  22:35:51  Show Profile
Another thing: Don't push the tiller all the way over close to 90 degrees--there it acts more as a brake than a rudder. If you limit yourself to about 45-50 degrees, the boat will turn as sharply as it is able to, which is pretty sharply.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
I really hate to disagree with Dave. He is clearly a man with a lot of sailing knowledge and he's always generous with his help but......
This "45 degree " thing isn't always true. We've just recently had this discussion. The rudder can certainly be effective past 45 degrees. Particlularly at slow speeds. Maybe, <font color="red"><b>ONLY</b></font id="red"> at slow speeds like when you're approaching your dock. Once the turn begins, the angle of the rudder decreases relative to the direction of stern travel. So, I agree that you shouldn't quickly turn your rudder 90 degrees. <font color="red">BUT</font id="red">, slowly going "hard over" <b><font color="blue">as the turn progresses </font id="blue"> </b> <s>may be </s> is very helpful in maneuvering the boat in tight spots around a dock.
I guess the point of all this is that in sailing, like most other life endeavours, there are few absolutes.
Response Posted - 05/19/2008 :  23:05:31  Show Profile
Sort of true, John, but essentially only if the engine is pulling/pushing the stern in the same direction. Otherwise, 90 degrees just doesn't work well, and should be resisted in <i>most</i> situations. Basically, the boat turns only if it's moving, and a hard-over rudder just slows it down. I bring it up from time to time because it's somewhat counter-intuitive and a common error. Peter's experience is evidence of my (and Frank's) point.
BTW, in reverse, the rudder really <i>wants</i> to go hard-over, so it's even easier to make that mistake.
Edited by - Dave Bristle on 05/19/2008 23:18:27
Response Posted - 05/20/2008 :  05:11:32  Show Profile  Visit OLarryR's Homepage
Actually, the only thing you did wrong was launching when there were spectators present. Rcmd practice first times out when no one is around - Then you will do great ! and if you don't....then there is no one to document the event and you then do not have to tell anyone. Only tell the story when you do it right ...and in front of the spectators. They will be impressed and we will marvel over your proficiency !
Response Posted - 05/20/2008 :  08:00:50  Show Profile  Visit Frank Hopper's Homepage
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by OLarryR</i>
<br />Actually, the only thing you did wrong was launching when there were spectators present. Rcmd practice first times out when no one is around - Then you will do great ! and if you don't....then there is no one to document the event and you then do not have to tell anyone. Only tell the story when you do it right ...and in front of the spectators. They will be impressed and we will marvel over your proficiency !
I hear the good spirit in this post BUT... if you are not competent then you owe it to the owners of the boats around you to have a few spotters around. AND if you do hit someone's boat be sure to tell them about it no matter how slight the bump.
Few things tick me off like watching a boat bounce of someone's outboard and then watch the skipper check his own boat for scratches and sail away.
Response Posted - 05/20/2008 :  08:07:29  Show Profile  Visit Prospector's Homepage
Hey Knightwind - we also had a bit of a rodeo trying to get our boat out of the launch slip.
What gave us trouble was:
Too low revs to overcome the wind when reversing out (due to engine trouble)
The engine not wanting to stay in the "down" position in reverse. There must be a tilt lock that I have yet to find.
And that the weather for the weekend was incredibly crappy, and I can't remember a 2-4 thats been this awful in recent history.
We were fortunate that no one else was a round and that the crane operator was patient while we sorted things out.
If you want folks on here to know what you mean with the 2-4 weekend, just tell them you celebrate memorial day a little early
Edited by - Prospector on 05/20/2008 08:07:50
Response Posted - 05/20/2008 :  08:56:04  Show Profile
Sometimes we think we have to use the motor, just because we <u>have</u> one. It's often easier to untie all the lines, walk the boat back, and step aboard, giving it a push out of the slip as you step aboard. Whether it's easier to push it out or to use the motor depends mostly on the wind direction. Before you leave the dock, check the wind and decide which will be easier.
Cbucki1
Response Posted - 05/20/2008 :  09:08:24  Show Profile
May 24..gosh I miss canada...eh!
Hope you had a 24 pack of Molson to celebrate the long weekend
Response Posted - 05/20/2008 :  10:44:03  Show Profile
I'm with John, my rudder goes passed 45 degrees every time I come into the slip.
When coming in to the slip with the outboard in neutral, I sit up on the transom ledge with my back against the stern pulpit and when I do my pivot, my tiller is up against my chest.
As you can see in this picture, we barely have a boatlength to manuever between the docks, so the ability to pivot on one's keel is extremely helpful.
Edited by - dlucier on 05/20/2008 11:47:07
Response Posted - 05/20/2008 :  13:13:33  Show Profile
OK, OK... I'll give you 75... All I'm saying is I've seen people push it hard over and run into things. And in reverse, it tries to push <i>itself</i> all the way over, and people run into things. I was trying to help a newbie understand why his boat didn't respond as he thought it would, due to prop-walk and rudder-brake.
UH-OH... Copyright infringement...
Edited by - Dave Bristle on 05/20/2008 13:15:19
Response Posted - 05/20/2008 :  21:59:29  Show Profile
Don,
I'm in the same boat as you. I've got only a few more feet than you to manuever and the wind is almost always across my slip. Once I get most of the way out of my slip I swing the tiller and the motor to get the back of the boat coming around and I usually have the tiller in my chest. Once I get the back moving in the direction I want I kick it into forward and swing the rudder and motor to the other side and the boat pivots around the keel and I'm on my way.
If I didn't swing the tiller and motor as hard as I do I would have a lot more turn to complete after shifting into forward.
