 deteriorating gelcoat
cat78
Initially Posted - 05/26/2008 :  17:13:47  Show Profile
My 78 C25 is starting to develop cracks in the gelcoat. I have seen this on other older fiberglass boats. They are not stress cracks it looks more like the gelcoat is shrinking or deteriorating like paint on an old house or antique piece of furniture. Has anybody had this problem and whats can be done about it
Response Posted - 05/26/2008 :  18:28:45  Show Profile
Most of us have... They're called "spider cracks" in the trade. In my experience (with a few boats) a common place is on an inside curve, such as between a coming or bulkhead and a seat. I've been told it's because the gelcoat was a little to thick there, and therefore shinks more than normal--who knows. Most attempts to repair them that I've seen looked worse than the cracks after a few years. To do a reasonably good repair, I suspect you need to open up the crack to maybe 1/16", apply a bead of gelcoat patch--as many layers as it takes to it above the surface--and then sand it down flush. From using the gelcoat patch in a tube from WM for some other kinds of dings, I'd say it should be possible to get a decent result.
Edited by - Dave Bristle on 05/26/2008 18:29:58
Response Posted - 05/27/2008 :  08:35:44  Show Profile
I agree with Dave that most do-it-yourselfers don't have the skill to repair them neatly, and it's too expensive to hire it done. Usually they aren't structural. If they begin to look so bad that you can't live with them anymore, you can repair them and then paint the whole boat. The paint will cover the repairs. I haven't painted a big boat, but painted a small dinghy, and it turned out nicely with modern paints, which seem to be reasonably DIY-friendly.
