 alcohol stove?
scottsails
Initially Posted - 10/26/2001 :  15:00:20  Show Profile
Just bought an '85 C25 and was curious how to use the alcohol stove,or would it be better to replace it with a propane stove or...?Open for any help or suggestions.
Thank you,
Scott "Shak'n Knot Stir'd"
Edited by - scottsails on 10/26/2001 15:1
tinob
Response Posted - 10/26/2001 :  15:56:38  Show Profile
Scottsails,
The stove you are curious about AKA curtain burner is , if directions are followed, a safe reliable stove. I think the problem is related to folks coming on board an older boat without the directions available to the original owner. I r
John Mason
Response Posted - 10/26/2001 :  17:01:57  Show Profile
When I first bought my boat (an '82) last November I took the stove into my shop to clean it up and test it. I didn't have a manual, but did it like Val described above - let a little fuel into the priming pan and light it, wait and then light the burner
RichardG
Response Posted - 10/26/2001 :  17:12:34  Show Profile
Expanding on Val's response, during the "priming" process I usually wait until the liquid alcohol is nearly completely burned before I open the knob. In "priming", you are simply heating up the stove elements so that the alcohol that thereafter comes out
sshaw
Response Posted - 10/27/2001 :  23:17:48  Show Profile
I agree with what's been said and have one more tip. I always have the pan to be heated ready on the opposite burner from the one I am lighting. As soon as I light the burner I more the pan over the lit burner. If you got a little too much alcohol into
JD van Wyhe
Response Posted - 10/28/2001 :  16:38:00  Show Profile
Scott,
Another thought on alcohol vs propane. I think one of the benefits of alcohol is that an alcohol fire, were you to have some catastrophe, can be doused with water. Propane, while easier to light, has the drawback that it's heavier than air. If
n/a
deleted
Response Posted - 10/28/2001 :  18:48:25  Show Profile
A much better method for preheating the burner is as follows. Fill a small plastic bottle (such as from contact lens cleaner) with alcohol. Now use the bottle to spray about 1-2 tablespoons of alcohol to the brass fitting below the burner. Light it and le
johnwprice
Response Posted - 10/28/2001 :  22:11:17  Show Profile  Visit johnwprice's Homepage
Scottsails,
johnwprice
Response Posted - 10/28/2001 :  22:15:27  Show Profile  Visit johnwprice's Homepage
[:I Well, I messed that one up, didn't figure out how to make a reply on the earlier one. Anyway, Val, thanks for a very good suggestion as to what to do with the curtainburner.:) We live in an all-electric house, and now, thanks to you, we have a backu
Rick Heaverly 86 C25 5382
Belize
Response Posted - 10/29/2001 :  06:58:44  Show Profile
I've tried both ways of preheating and it still flares up! The Admiral wont let it on the boat. Could I possibly have a leak?
Rick Heaverly
kenobie51
Response Posted - 10/29/2001 :  08:32:51  Show Profile
Rick,
Do you mean it is flaring up durring preheat, or after you light the burner?
I use mine all the time with no problems. As said above, the preheat with just enough fuel is the secret. Then light the burner. The burner flame should then be steady an
Bill Holcomb
Response Posted - 10/29/2001 :  09:35:48  Show Profile
OK all.......
While it's true that the Princess stove that came on C25s can be used safely if one either knows the procedures or practices carefully, I can say emphatically that changing to a non-pressure alcohol stove made by Origo was one of the best
Bristle
Response Posted - 10/30/2001 :  23:49:51  Show Profile
Here's another vote for the Origo... Safe, simple, maintenance free, and did I say SAFE? Our pressurized unit came out of the boat right after we bought her.
Dave Bristle, 1985 C-25 SR-FK #5032 in CT
frich
Response Posted - 10/31/2001 :  07:20:37  Show Profile  Visit frich's Homepage
I believe that my stove is original to a 1984 Cat 25. The previous owner gave me the owners manual for it. If anyone would like a copy email me at frich1230@aol.com and i will send it.
tinob
Response Posted - 10/31/2001 :  15:42:40  Show Profile
tinob
Response Posted - 10/31/2001 :  15:56:25  Show Profile
To John W Price,
I guess by now you realize that you don't own the pattern on screwed up entries, get in line, behind me, if you please.
I was desperate for heating elements at home to cook up all the produce going ripe and thought to add the b
n/a
deleted
Response Posted - 11/01/2001 :  08:23:23  Show Profile
I also have been trained using pump-up, white gas backpacking stoves and am used to the priming procedure. The key is the pre-heat of the burner. A couple of teaspoons of alcohol in the little cup at the base of the burner assembly will usually pre heat t
George
Response Posted - 11/04/2001 :  20:18:42  Show Profile
Hi Scott,
Meant to tell you about the C-25 association but guess you found it. Re the 'curtain burner', you will find the operating manual in the binder with the boat info. Starboard fire extinguisher is the new one, just in case. :) Was planning to in
Response Posted - 11/06/2001 :  16:37:47  Show Profile  Visit Champipple's Homepage
Hey Scott,
We decided to toss the stove after the first year of ownership. The entire unit had seen its better days. We bought a propane grill that hooks on to the stern rail, it does the job for most things, I also have a old style cermaic type camp
billfred
Response Posted - 11/11/2001 :  07:11:09  Show Profile
Does anyone have the manual for the Princess stove? I just acquired
My C25 and no maunal was available. Looking primarly for the parts list. Are parts still available?
billfred
Response Posted - 11/11/2001 :  07:11:17  Show Profile
billfred
Response Posted - 11/11/2001 :  07:11:26  Show Profile
Ron A
Response Posted - 11/26/2001 :  15:41:00  Show Profile
I was skeptical of the pressurized alcholol stove from the moment I saw it. My wife is not impressed and will not use it. I too took it home to "learn" how the thing works and I can't get it to work. The knobs don't turn well and after reading all the c
Ken Cave
Response Posted - 11/26/2001 :  23:20:08  Show Profile
For what it's worth department:
Some of the folks have gutted out their original stoves and have purchased a propane camp stove, and inserted the parts in the original stove. Using a small bottle is easy and will last about four days without changing
Tony Dillon
Response Posted - 11/27/2001 :  11:10:54  Show Profile
We have converted to a propane camp stove also. We also have a propane Magma BBQ on the stern rail that we added the conversion cap to use it as a stove. Marge prefers cooking on it when the weather is cooperating.
Tony Dillon
Mental Floss
RichardG
Response Posted - 11/28/2001 :  19:14:02  Show Profile
I have the Princess owners manual (including parts list) in "pdf" format -- i.e. I can e-mail it.
What is the procedure for putting the manual in the "Brochures and Manuals" section of the web site? I think it would be appropriate to have it there for
