 How Do You Empty Your Water Tank?
MartinJW
Initially Posted - 09/16/2008 :  09:27:51  Show Profile
Sadly, we've hauled our boat out for the season, and now we need to empty the freshwater tank for the winter.
Does anyone have any tips for doing this quickly and easily?
We still have about 10 gallons of potable water in our tank. I've been using the hand pump to empty it, but this looks like a very, very slow method.
Thanks!
Martin
C25/250 Int'l Ass'n Member
2008 C-250 WK #973
"Bluebell"
Lake Tahoe, CA/NV
Response Posted - 09/16/2008 :  09:36:34  Show Profile  Visit delliottg's Homepage
Martin,
Short of pulling hoses, there's no easy way to do this. Rita & I can empty the tank in about 20 minutes of pumping the faucets in the head & galley at the same time.
Before you do, a bleach solution in the tank will help prevent any nasty growths over the winter.
Response Posted - 09/16/2008 :  10:00:38  Show Profile
I have never had a marine head. Is there an advantage to emptying the waste tank and then flushing the freshwater through the head plumbing and then emptying the waste tank again? ... as a way to flush out the marine head system.
Response Posted - 09/16/2008 :  10:53:03  Show Profile
<br />I have never had a marine head. Is there an advantage to emptying the waste tank and then flushing the freshwater through the head plumbing and then emptying the waste tank again? ... as a way to flush out the marine head system.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Yup, and then putting a few gallons of marine/RV antifreeze in the water tank, pumping it through to the head and sink, and "flushing" it into the holding tank.
Response Posted - 09/16/2008 :  12:12:56  Show Profile  Visit delliottg's Homepage
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Yup, and then putting a few gallons of marine/RV antifreeze in the water tank...<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Dave, are you referring to the potable water tank? I'm not so sure running antifreeze through that is a good idea. Even after flushing it out there would still be chemical residue that would be unhealthy at best. Antifreeze is lethal in concentration. Please elaborate.
On our boat, we (and by we I mean my dog & I) drink the water from the potable water tank. Rita won't drink it, but that's a different story. We don't have a head, we use a porti-potty, so flushing the system is just the head & galley faucets for us. Still, I wouldn't want to be drinking antifreeze contaminated water.
Edited by - delliottg on 09/16/2008 12:15:46
Response Posted - 09/16/2008 :  12:28:22  Show Profile
I'm sure that Dave's referring to the type of anti-freeze used in RV potable water systems. Here's an example: [url="http://www.peakantifreeze.com/rvmarine.htm"]Peak RV & Marine Antifreeze[/url]
Response Posted - 09/16/2008 :  12:35:19  Show Profile  Visit delliottg's Homepage
Ah...thanks for the clarification John. I wasn't aware that they made potable-water-safe antifreeze.
Breezy Cat
Response Posted - 09/16/2008 :  12:40:02  Show Profile
Here in the Northeast it does freeze but I haven't drained the tank in years.
Usually the tank is about half full at the end of the season and that is plenty of room for the water to freeze and expand.
Although I only use the water for cleaning the less chemicals the better.
Opening the valves is good idea but not necessary.
So if your tank is topped off drain some, if it is half full you’re probably OK.
I believe water expands approximately 10% when it freezes.
Response Posted - 09/16/2008 :  13:07:51  Show Profile  Visit Prospector's Homepage
Actually Breezy, water is at its densest at 4 degrees celcius, and its volume expands from there to either form steam if it is heated, or as space within its crystalline structure as it freezes. It is this continued expansion that causes pressure ridges in frozen lakes in the winter. Of course I am referring to a Canadian deep freeze which I believe is more severe than your experience. But I digress.
You may want to consider a few options for draining the tank. Some of these are better than others.
Option 1 - Run a hose from the tank out the cockpit drains, and let it fall on the ground. Start a siphon and walk away. The 4 foot drop should be enough to drain most of the water.
If your tank doesn't have an access hole (mine does), you may be able to run clear plastic hose down into the filler and siphon it up and over the side of the boat. A small enough diameter hose should fit down into the tank. A small diameter would mean slower siphoning, but there is the allure of the "then walk away" step.
Option 2 - Same thing, only use the bilge, then pump away (unless you have an automatic bilge pump in which case you can walk away.)
Option 3 - Hire some kid to pump it for you. Then walk away.
Check your tank for an inspection/access port. Ours has a 3" hole in the top of it with a fitting. You may be able to open the port. Then you could use a manual bilge pump (or any other pump) to empty it. If you don't have such a hole in your tank - well, you're back to hiring a kid or siphoning.
Edited by - Prospector on 09/16/2008 13:09:53
Response Posted - 09/16/2008 :  13:13:18  Show Profile  Visit britinusa's Homepage
We have a freshwater power washdown pump, so we just turn that on for 10 mins and the tank is empty. We have 2 tanks so when one is empty we switch over the supply valves and repeat for the second tank.
just another advantage of the power washdown pump!
Response Posted - 09/16/2008 :  15:41:26  Show Profile
If your boat is near a water spigot, simply lead your garden hose up into your boat then into the bottom of the water tank. Next, turn on the water at the spigot until it starts flowing into the water tank. Once it's flowing, turn off the water and disconnect the hose at the spigot. The water in the hose should then start the syphon.
glivs
Response Posted - 09/16/2008 :  18:25:08  Show Profile
An inexpensive garden hose on-off valve from HD or your local Ace Hardware allows you to fill your hose either at home or at the boat yard and carry it on-board with no or little water loss. Insert the end of the hose with the valve into the water tank with the other end on the ground. Open the valve to start the siphoning.
Tom Potter
Response Posted - 09/16/2008 :  18:54:18  Show Profile
I'm with Paul, love the new wash down pump. Ooooh so many uses.
SEAN
Response Posted - 09/17/2008 :  08:40:43  Show Profile
me too wash down pump or stern shower nice up grades
