 Traveler Replacement
Alan Clark
Initially Posted - 12/07/2008 :  20:40:25  Show Profile
We are replacing the Traveler on our 1987 TR/SK and have purchased new cleats From Catalina Yachts, Has anyone removed the travelor camcleats from the stern and if so how did you access the screws?/ Bolts? Much Thanks
Alan & Eileen
2001 Catalina 310 Hull #155
"Anam Cara"
ex-1987 C25 TR/SK #5612
"LEPRECHAUN"
Troy Ohio USA / Lake Erie-Catawba Island
ASA 101 103 104
"The clink of an anchor - chain, the 'Yo-Ho!' of a well time crew, the flapping of huge sails - I love all these sounds."
John 'Rob Roy' MacGregor
Happy D
Response Posted - 12/08/2008 :  06:32:01  Show Profile
On my 77, the traveller cam cleats are bolted to a piece of brass that is embedded in the fiberglass. There were no nuts to remove. I just unscrewed it. Try and pull one screw out on the port side and see.
It's easier to reach under the coaming on the port side to tighten it back up if it ends up having a nut.
PZell
Response Posted - 12/08/2008 :  11:13:03  Show Profile
If you plan to bolt on there, here's a tip: It is pretty hard to get a nut up to the bolt in that narrow space. But, your finger can probably reach to the bolt. What I did was put a little dab of caulking on my finger and stick the nut on the tip. That way I was able to start threadding.
Alan Clark
Response Posted - 12/08/2008 :  11:38:24  Show Profile
Great Ideas, I have not looked up there as the only way I can do that is with a mirror, I did Loosen One srew but it wont come out..Hmmmm
But since the boat is in storage , I will try to get to it in a couple of weeks . I will let you know ..Thanks and Stay Warm!
Happy D
Response Posted - 12/08/2008 :  17:23:08  Show Profile
Yeah, they may have quit imbedding a plate into the fiberglass by 1987.
