Jim, can you get photos of your "invention" taken? This sounds like an excellent inclusion for the tech section. I know I'd sure like to see what it all looks like, including some shots of you doing the entire process. Many of us could benefit by your
I guess removing the engine all depends on how much you can lift. If you cant lift then you need to come up with some sort of mechanical advantage. I just had my boat hauled with the motor still on. Once on the stands I undid the motor clamps and lifted t
With our boat on stands, I ran a dock line from the stern rail down to the handle between the outboard clamps, back up to the stern rail, and down to the stern cleat. Then, from a ladder, I slid the engine off the bracket, uncleated the line, and eased i
While we're on the subject... When I got my C25 it had an older Honda 9.9 on it... methinks a late 80's vintage. It's given me a couple of bad moments and now won't idle well (which leads to some exciting moments when coming into the slip). I have a deci
My 1986 7.5 Honda would not idle. After several trips to the shop I had to learn to fix it myself or get a second on the house. My problem turned out to be dirt in the fuel system. The idle circuits on the carb can be cleaned by removing the i
I for one would NOT recommend getting a 2 stroke motor. For a few hundred more you can get a new 4 stroke. Keep in mind at some point the EPA ( our friends, right?) are gonna ban 2 strokes. And as far as the idle problem....sounds like dirt in the carb
well, as for the 2 strokes being banned.. I think that happens in 2006 (except already in California). But, I'm told that will be a ban on the sale of new motors, not a ban on the use of existing motors. Besides, I'm in SW Louisiana where the water glows
I believe the shaft length is measured from the top of the transom mount (where the engine rests on the boat or bracket) to the cavitation plate, as that is the point of the engine that really must be under water.
Sam, I was faced with a similar situation, but I considered an additional option: rebuild the old motor. I had it serviced fairly thoroughly with all replaceable parts replaced AND I added an electric starter. That was 2 years ago and it purrs like my c
I bought a Tohatsu 9.8 long shaft 2 stroke manual start today for $1445.00. From what I've seen that's a very good deal. Now I'm going to pull that Honda off and either sell as is (one just went on eBay for $500.00 without a photo and only stated it "runs
