 Swing Keel Up or Down?
tod
Initially Posted - 01/29/2009 :  13:45:02  Show Profile
An earlier topic got me to thinking, "Is it better to leave your swing keel up or down if your boat stays in fresh water?"
'85 Catalina 25 TR
#4967, South Carolina
Even Chance
Response Posted - 01/29/2009 :  13:58:13  Show Profile
Zillions of threads on this in the archives. The C25 handbook says up, many users say down (reason #1 being prevention of catastrophic damage from a keel falling because of cable breakage). I pull mine up because I'm in saltwater and believe up lessens corrosion on the pendant (and the instructions say up, and the PO said up, and the boat's had five cables in 24 years). If I were in fresh water, it would be a no brainer: absolutely down. Search the archives.
Response Posted - 01/29/2009 :  14:47:39  Show Profile
Totally agree!
HeelinPatrick
Response Posted - 01/29/2009 :  14:50:39  Show Profile
How many people have had a cable break? Cause/how to have prevented it?
Response Posted - 01/29/2009 :  14:53:38  Show Profile
Also: I believe in zincs (magnesium alloy in fresh water) on the keel if you stay in water for the season - I am fresh in the summer and salt in the winter and am on my second set in 3 years. The book says one on each side near the pivot, and I believe in a a third near the cable attachment.
tod
Response Posted - 01/29/2009 :  15:54:15  Show Profile
Dave, I've never used zincs. how are they attached? Can it be done in the water?
Response Posted - 01/29/2009 :  21:51:28  Show Profile
Hi Tod... I believe Val Bisagni (Tnob) experienced <i>two</i> sinkings before he converted his swing to a wing. In salt water, up vs. down is a tough choice--perhaps why Catalina advised against keeping the swinger in salt water.
To mount zincs, you should drill and tap the cast iron for some short bolts. Don't use the normal "NevrSeize" on the threads--you want metal-to-metal contact. You can use stainless bolts--they are just conductive enough--to ease removal and replacement later.
Response Posted - 01/29/2009 :  23:49:42  Show Profile
I would find it interesting to know how many have had a cable break, but I doubt that we could ever get a reliable number. Inspect your cable and its attachment every season and replace it if there is any question or if 5 years (some suggest more frequently) has elapsed. You can buy cables from CD or have them made by a rigger for less. I use zincs, it may be voodoo, but I've never had a problem - the underwater parts have always looked good and my winch isn't corroded. The keel drills and taps pretty easily - two holes for each teardrop zinc when the boat is out of the water, and mount the zincs so they are facing forward when the keel is down. I can give you WM part numbers later, along with hints and a diagram if you want.
skrenz
Response Posted - 01/30/2009 :  12:19:10  Show Profile
Dave,
Please do send WM part numbers and diagrams. Perfect thing to do on a January afternoon on the hard.
Response Posted - 01/30/2009 :  13:28:38  Show Profile
Dave - please include me on your tips when forwarding - THANKS!
Deric
Response Posted - 01/30/2009 :  16:12:50  Show Profile
CD has the cable and related parts. They recommend replacing every two years. Compared to the price of repair, it is a small fee as part of preventative maintenance practice.
Deric
Response Posted - 01/30/2009 :  23:44:19  Show Profile
CD is convenient and good products, but I had mine made at my marina for half the price. I'll try to email a diagram tomorrow. WM part that I use (3): <b>Hull Anode - 3 1/2"L x 1 3/4"W x 1 3/8" thickness 110312 CMT20 Only $6.99 USD</b>
