 Rudder Noise
JoergK
Initially Posted - 07/07/2009 :  21:26:00  Show Profile
It's just a very small ticking /clicking noise which drives the unhappy occupant of the quarter berth nuts. We are at anchor for the night. The lower pintle moves ever so slightly in the gudgeon. I tried immobilizing the rudder by jamming a towel between rudder and transom, used shock cords ... nothing works to eliminate the ticking.
Is there a bright idea of how to deal with this nuisance?
Thanks for listening.
Joerg
Joerg
2002C250 WK "BerLyn"
cat25
Response Posted - 07/08/2009 :  05:15:49  Show Profile
Try putting a 1/2 nylon washer on both the pringles that might do it
Response Posted - 07/08/2009 :  07:16:33  Show Profile
As you probably guessed, your gudgeon is worn. Catalina Direct sells new ones with nylon bushings that should eliminate that. You might be able to find similar bushings in a hardware store, although they might require drilling or reaming the gudgeons a little. The lower one is easy to replace (with a helper)--the upper one doesn't require the helper, but it requires cutting a hole in the cockpit and installing a Beckson inspection plate.
Meanwhile, you could remove the rudder and lay it in the cockpit for the night. A "quick release" pin, shaped sorta like an R, might help.
Edited by - Dave Bristle on 07/08/2009 07:24:20
Response Posted - 07/08/2009 :  07:21:20  Show Profile
I had a problem with rudder slop from worn gudgeons. I bought 2 bronze bushings from Ace Hardware and had them lathed to a tight fit (in fact we had to force the gudgeons into the bushings). No more rudder slop and smooth steering.
Response Posted - 07/08/2009 :  07:26:47  Show Profile
<br />...we had to force the <b>gudgeons</b> into the bushings...<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">I'm confoozed... Do you mean the pintles?
Edited by - Dave Bristle on 07/08/2009 07:27:11
JoergK
Response Posted - 07/08/2009 :  11:21:19  Show Profile
Tks, guys.
I'll order the replacements.
Response Posted - 07/08/2009 :  13:45:36  Show Profile
Ooops! Sorry Dave - had a senior moment...
Response Posted - 07/08/2009 :  18:24:33  Show Profile
I just looked at CD's site--they offer a kit for installing the inspection port for the upper gudgeon--you can even rent the hole saw from them. Those guys are good!
