I will soon be taking a drill to the mast and boom for the first time to install some blocks and fairleads for a new reefing system. Can I use self tapping SS screws or should I drill and tap each mounting point?
I moved our turning blocks aft on the <edit><s>mast</s> <b>boom</b> </edit> and re-used the self tapping screws that the PO had installed the first system with. Worked fine.
A tip... put the turning blocks 6" or so further aft than you think you need. There is lots of real-estate there and you may as well use it. Pulling the sail back when you reef will give it better shape.
If you use self-tapping screws, be sure to have a few extras on hand. I've ruined the head on SS screws before doing that. The mast is another matter. It will likely be a thicker extrusion. Just go slow.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by dmpilc</i> <br />If you use self-tapping screws, be sure to have a few extras on hand...<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">...and a mini Vice-grip to remove the screw after the head twists off.
You need to tap any hole you drill, it takes a minute and will allow to screw anything in and out. Self tapping screws don't work in anything that thick.
Also, select SS bolts that are just long enough for the item you are attaching and the boom/mast thickness. That way you wont have a bolt (worse yet screw) getting in the way of, or catching on, internal lines inside the boom or mast.
All of the above, depends on the hardware. SS base plates are thin so pop rivet work well. Cast aluminum base plates are thick and I prefer to drill and tap but have used self tapping screws often. On the end of boom reefing cheek block, don't put it too far back. It should only be about two or three inches back from the reefed clew, otherwise the angle is wrong and the reef line does not pull down enough.
