 Outboard motor for Dinghy
Initially Posted - 08/07/2009 :  05:27:08  Show Profile  Visit britinusa's Homepage
Our new dink arrived, inflated, looks pretty good!
Now to make the outboard/oars/electric power choice.
We will be using the dink to transit from the boat(anchor/mooring) to shore, or between boats.
Most of our sailing is within sight of the shoreline but that is either the quiet waters of the inner side of the keys (most of the time) or the not so quite waters on the Atlantic beach.
Any suggestions?
If outboard or electric: size/length/make/etc.
Joint Decision. (Sold)
PO C250WB 2005 Sail # 841.
Moved up to C34 Eximius
Updated August 2015
Response Posted - 08/07/2009 :  06:53:24  Show Profile
If you just want to move along (not plane) and keep weight to a minimum for ease of mounting and removing, there are two that I'd suggest:
Honda 2: 4-stroke, 28 lbs, air cooled (no cooling system issues), somewhat noisier (because of air cooling), centrifugal clutch (throttle up and the prop engages--down and it disengages), 360-deg. steering (no reverse or true neutral), internal gas tank.
Suzuki 2.5: 4-stroke, 30 lbs, water cooled (somewhat quieter), F-N shift, 360-deg. steering, internal gas tank.
Nothing else I know of comes close for weight. Both will push a dink to hull-speed--considerably more power and weight is needed to get on plane. A friend recently bought the Suzuki after trying my Honda--it's a nice little motor.
Edited by - Dave Bristle on 08/07/2009 06:55:35
Response Posted - 08/07/2009 :  08:14:48  Show Profile  Visit DaveR's Homepage
Paul,
I've got the Suzuki 2.5 and love it. Nice and quiet, plenty of power.
David Scott
Response Posted - 08/12/2009 :  20:41:25  Show Profile
We opted for the Tohatsu 3.5hp 4-cycle o/b for our West Marine RU260 inflatable dingy. Its important to match dingy and motor and this dingy reportedly handles a max of 4hp. At 42lbs. its a bit heavy to manage one handed as was the case with our old 2-cycle and 2hp Yamaha. We used a vang attached to end of boom to lift engine on and off boat so this solved problem of a heavier o/b. We just returned from a 7wk trip to the Northwest and had good opportunity to test it. It worked well for us. It gave us a little more power then the old 2hp o/b when carrying stuff from shore to boat,it was compatible with our main o/b a 9.8hp Tohatsu,and if main o/b failed it could in light conditions help be a backup o/b for the boat.
Response Posted - 08/13/2009 :  04:56:58  Show Profile
I don't use a dinghy, but my sailing pal has a 2.5 hp Mercury 2-stroke. It replaced his electric dinghy motor, which was very tedious to use by transferring a heavy battery to and from the dinghy each time. The 2.5 hp Mercury is lightweight and gives enough power to use as a backup motor to drive his C-25 at 4 knots. The 2 stroke is a bit smoky and noisy, of course, so I would recommend one of the new, small 4 strokes.
Response Posted - 08/13/2009 :  14:06:03  Show Profile  Visit piseas's Homepage
Paul, what is the max HP it will carry? I have a 8.5' dinghy and got a 6hp Tohatsu. It was the same weight as a 4hp and not more more in price. I wanted larger HP for my needs. I am extremely happy with it. It weights much less than a Honda.
Steve
Response Posted - 08/13/2009 :  17:48:37  Show Profile
the air cooled Honda is light, but it's <u> a lot noisier</u> than 2 and 4 stroke water cooled engines. I've used my electric for many things, but I wouldn't want to get caught in the surf with it.
Response Posted - 08/13/2009 :  18:14:00  Show Profile  Visit britinusa's Homepage
Still working on the Engine option.
Plus I'm really re-visiting the Arch concept to carry the dink
Response Posted - 08/13/2009 :  18:35:23  Show Profile
Hint: I bought the Honda 2, but I would've bought the new Suzi 2.5 if they'd made it then. Either is plenty for my 8'6" Achilles, and both are much lighter than anything else now being made, which only matters if you don't have a davit to lower and lift it.
Edited by - Dave Bristle on 08/13/2009 19:47:24
