 Looking for ST 1000 Mount
BruceL
Initially Posted - 08/10/2009 :  16:58:43  Show Profile
Hi I'm looking for the bulkhead mount and extension
for a Raymarine ST1000 Autopilot.
Any help Please
Bruce
Ed Cassidy
Response Posted - 08/10/2009 :  17:43:41  Show Profile
I don't have an extra but FYI, the Simrad cantilever mount also works for the ST1000.
millermg
Response Posted - 08/11/2009 :  10:41:23  Show Profile
This is what you need, off the Raymarine website. http://www.raymarine.com/ProductDetail.aspx?product=2203
Ed Cassidy
Response Posted - 08/11/2009 :  10:56:35  Show Profile
The reason I mentioned the Simrad was becasue I found one on eBay for $15 and decided to see if it would work. It did and I saved $60.
BruceL
Response Posted - 08/11/2009 :  16:16:05  Show Profile
Thank you for the heads up on the Simrad mount I'll keep my Eye on E-bay for it.
Response Posted - 08/12/2009 :  07:54:55  Show Profile
If your trying to save some money you could make your own. A couple of galvanized pipe fittings would work. Fill one end of the pipe with epoxy resin and drill the appropriate size hole for the autopilot's pin.
Ed Cassidy
Response Posted - 08/12/2009 :  09:33:11  Show Profile
I actually did that first and it does work. I didn't fill mine with epoxy, I just drilled a hole through both sides of the pipe.
millermg
Response Posted - 08/12/2009 :  10:57:34  Show Profile
<br />If your trying to save some money you could make your own. A couple of galvanized pipe fittings would work. Fill one end of the pipe with epoxy resin and drill the appropriate size hole for the autopilot's pin.
I would be a bit hesitant to put anything but aluminum or stainless steel on my boat- it will rust!
Edited by - millermg on 08/12/2009 10:58:18
jimhart
Response Posted - 08/13/2009 :  09:35:23  Show Profile
I too used the pipe fitting.
Has worked well.
BruceL
Response Posted - 08/13/2009 :  10:44:57  Show Profile
OK the pipe fitting sounds great
I have found an Aluminum one but what size did you go with 1/2 or 3/4 pipe?
Ed Cassidy
Response Posted - 08/13/2009 :  11:03:46  Show Profile
If you intend to fill the pipe with epoxy, use the 3/4 and only drill through the top side of the pipe. Make sure you can unscrew it from the side of the seat to get it out of the way when not using and be sure to use a backing plate. The fiberglass is not all that thick where it needs to mount. And don't forget to post pictures of the completed project!!!
Response Posted - 08/13/2009 :  11:06:16  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">I would be a bit hesitant to put anything but aluminum or stainless steel on my boat- it will rust!<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Galvanized Steel is used because of its resistance to rust. While I am sure it can rust, so can stainless steel.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">I have found an Aluminum one but what size did you go with 1/2 or 3/4 pipe?
A lot of stress on this part. If the 3/4" pipe is thicker I would go with that. The "galvanized" steel will be much stronger in the long run.
