 Cleat backing plates
tbosch
Initially Posted - 08/18/2009 :  20:25:52  Show Profile
I was peaking behind the panels above the quarter berth and was surprised to see that there are just a couple of plain washers backing the bolts of the deck cleats just aft of the winches. The boat is a 1980 c25 std rig. I looked in the dumpster under the starboard cleat and it's the same thing. That doesn't seem like enough. I can post a picture if anyone is interested but it just looks like a bolt, nut and washer. I haven't inspected the forward cleats but I suspect they are similar.
So, is this sufficient? Has anyone upgraded this configuration? Do newer boats have backing plates?
I think I'd like to put something beefier behind the cleats. Do I just buy bigger washers? Or are there plates I could buy that have flexible hole positions to fit my cleats?
Todd
Todd
1980 C25 SR/FK "Dora"
Response Posted - 08/19/2009 :  05:40:54  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by tbosch</i>
<br />I was peaking behind the panels above the quarter berth and was surprised to see that there are just a couple of plain washers backing the bolts of the deck cleats just aft of the winches...So, is this sufficient?<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
I, too, have a 1980 C25 with the original cleats and they have went without issue for almost thirty years now. Do I think I need to add backing plates? No, not really. But then again, I'm not in a hurricane zone.
Response Posted - 08/19/2009 :  05:53:51  Show Profile  Visit DaveR's Homepage
I think you're talking about the jib sheet jam cleats and I don't think there's that much force being put on those. The winches do that. On the other hand a little overkill is a good thing.
Response Posted - 08/19/2009 :  06:51:08  Show Profile
Both the jib cleats and the mooring cleats have the same washers.
glen
Response Posted - 08/19/2009 :  11:12:49  Show Profile
I replaced the small original cleats with larger ones. Not because I thought there was an issue, but because I always lock my dock lines. For me the center hole in the original cleat was just too small. I installed a 1/4" thick, aluminum backing plate for each cleat. I have no idea if this was necessary, but like Dave Robbins said “a little overkill is a good thing”
Response Posted - 08/19/2009 :  11:47:10  Show Profile  Visit aeckhart's Homepage
I have an '88 C25 and, like Don, I've had my boat for 21 years with the same washers backing all the through-deck bolts. I've thought about replacing them because of some of the conditions I sail in on Lake Superior. Nothing has been able to pull those washers through the deck yet. I also moor my boat from the bow deck cleats. They've been through winds of 60 mph and 4' seas on our lake with no problems. Needless to say, I am not planning of replacing the washers any time soon.
tbosch
Response Posted - 08/19/2009 :  12:24:37  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by aeckhart</i>
<br />I have an '88 C25 and, like Don, I've had my boat for 21 years with the same washers backing all the through-deck bolts. I've thought about replacing them because of some of the conditions I sail in on Lake Superior. Nothing has been able to pull those washers through the deck yet. I also moor my boat from the bow deck cleats. They've been through winds of 60 mph and 4' seas on our lake with no problems. Needless to say, I am not planning of replacing the washers any time soon.
Hey, I'm on Superior, too! We sail out of Ashland, WI and the Apostle Islands.
Yours and other comments about the washers proving to be sufficient is good news. I won't put this upgrade near the top of my list. There are plenty of other things to do...
Response Posted - 08/20/2009 :  10:34:06  Show Profile  Visit aeckhart's Homepage
Todd,
I'm in Houghton, Michigan. Perhaps we can get together and exchange a weekend sail in our home area together. I've raced the Around the Islands race once on a Tartan 10 but have not sailed the Apostles otherwise. It's on my bucket list....if I had a bucket list. If not this year maybe next.
Al Eckhart
tbosch
Response Posted - 08/20/2009 :  11:39:06  Show Profile
<br />Todd,
Al Eckhart
That is a great idea. It will have to be next year, though. The boat is on a trailer right now while I finish a bottom job (among other things...).
Stu Jackson C34
Response Posted - 08/24/2009 :  23:04:07  Show Profile
The cleat bolts are in shear, so the backing plates do little if anything to impact the strength, it's just the amount of material in the bolts. F'rinstance, you could undo the nuts and washers underneath and still use the cleats. They aren't being pulled up by the direction of the line, are they? Hurricane alley? Too big is never enough. Your boat, your choice, now that you understand how it works.
Response Posted - 08/25/2009 :  05:31:21  Show Profile  Visit DaveR's Homepage
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"> They aren't being pulled up by the direction of the line, are they? <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Actually in tidal situations you often do get vertical tension. No huge amounts unless you tied off too tight but I think I'll leave the nuts on
