 Honda 9.9 engine handle issues?
SRH_Catalina_Newbie
Initially Posted - 09/06/2009 :  07:55:09  Show Profile
Is anyone having problems with their Honda 9.9 engine handle getting in the way of the motor mount lifting handle when you lift or tilt the engine?
SRH_Catalina_Newbie
Response Posted - 09/06/2009 :  11:52:52  Show Profile
I have mine on the Starboard side as well and I plan on using a 4 spring lift from Catalina Direct. I noticed that the tiller for the Honda is connected to the front of the engine not the side so I wondered if tht was an issue when tilting the motor.
Do you use the 4 Spring mount from CD or something else?
How fast do you go with a Honda 9.9 on you boat?
Even Chance
Response Posted - 09/06/2009 :  14:44:15  Show Profile
Starboard side: lift, no; tilt, yes. The handle is in line with one of the stanchions: swivel the engine a little when you tilt it and it makes all the difference. I have the 4 spring Catalina Direct mount.
I can motor at hull speed at about half throttle.
Edited by - Even Chance on 09/06/2009 14:44:59
