 Replacement Rudder for C25
mcdermott42
Initially Posted - 09/09/2009 :  23:24:56  Show Profile
Believe it or not someone stole my rudder and tiller from my '84 C25 when it was at it's mooring in San Diego's Mission Bay. I'm planning on ordering a new one from Catalina Direct unless someone has a better (more economical ?) idea.
Mike
Response Posted - 09/10/2009 :  05:47:08  Show Profile  Visit DaveR's Homepage
Hi Mike,
Did you try Ebay? Craig's List? You may get lucky and find one a little cheaper.
Edited by - DaveR on 09/10/2009 11:24:03
Response Posted - 09/10/2009 :  06:39:32  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by DaveR</i>
<br />You may get lucky and find on a little cheaper.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">It might even look <i>v e r y familiar!</i>
Seriously, if you had the original, unbalanced rudder, you'll appreciate the upgrade to the new balanced models--it's like power steering. Catalina Direct has three--a "standard" HDPE (solid plastic), "Blue Water" HDPE (thicker plastic), and (apparently) Catalina's balanced rudder that's foam-cored fiberglass . IMHO, the latter is better suited to ocean sailing--HDPE has a reputation for snapping in two. Check with CD about the $660 balanced rudder--I'm hoping that's the one Catalina started using in about 1987-88, and that I bought as an upgrade. That's the one I'd recommend.
Response Posted - 09/10/2009 :  08:44:14  Show Profile
Here's another place that produces foam cored rudders for the C25. I've never dealt with them, just found them one day while poking around, so I don't know if the C25 rudder they produce is the balanced rudder.
[url="http://newrudders.com/"]NewRudders[/url]
Response Posted - 09/10/2009 :  10:42:14  Show Profile
I just had a great customer service experience with Ida Sailor if that's worth anything in this equation. Give Peter a call.
Response Posted - 09/10/2009 :  14:45:11  Show Profile
do follow-up w/ Craig's List...it's well known that stolen electronics end up there, and more than one owner has recovered their gear...
mcdermott42
Response Posted - 09/23/2009 :  19:48:28  Show Profile
Thanks for the response, I bit the bullet and ordered a new "plastic" rudder with the tiller.
HeelinPatrick
Response Posted - 09/24/2009 :  09:33:14  Show Profile
Toss some ablative (sp?) on that puppy too, or what the green stuff grow on it.
Response Posted - 09/25/2009 :  06:23:54  Show Profile
I have the hdpe -- it works great and you will need ablative paint and do not scrub/clean mid season as the paint will rub off easily. Also, if you remove the rudder off season make sure you store it carefully so it will not warp.
Response Posted - 09/25/2009 :  06:56:55  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by bigelowp</i>
<br />...if you remove the rudder off season make sure you store it carefully so it will not warp.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">He doesn't know what "off season" means...
Response Posted - 09/25/2009 :  07:55:36  Show Profile
There use to be a derelict C25 moored off of the harbor patrol office there in Quivera Basin. You might talk to them and see if they will work with you. there was also a spinnaker pole laying on the deck.
Response Posted - 09/26/2009 :  18:24:53  Show Profile
Dave -- point taken! But then again does that make our Northern boats only half as old?
